Hi,I'm beginner at Arduino.I trying to make some projects.but I get this error message on Adafruit SSD1306 library.I read something about this is because of low flash.But I can't reduce my variable,all necessary.Can you help me please?
Here is my code.
#include <virtuabotixRTC.h>
#include <MPU6050_tockn.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// Example sketch for interfacing with the DS1302 timekeeping chip.
// Copyright (c) 2009, Matt Sparks
// All rights reserved.
// http://quadpoint.org/projects/arduino-ds1302
virtuabotixRTC myRTC(6, 7, 5);
#include <SPI.h>
#include <SD.h>
File myFile;
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
// The pins for I2C are defined by the Wire-library.
// On an arduino UNO: A4(SDA), A5(SCL)
// On an arduino MEGA 2560: 20(SDA), 21(SCL)
// On an arduino LEONARDO: 2(SDA), 3(SCL), ...
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(128, 64, &Wire, OLED_RESET);
MPU6050 mpu6050(Wire);
// seconds, minutes, hours, day of the week, day of the month, month, year
display.begin();
Wire.begin();
mpu6050.begin();
mpu6050.calcGyroOffsets(true);
if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
mpu6050.update();
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(SSD1306_WHITE);
display.setCursor(0,0);
display.print("X:");
display.println(abs(mpu6050.getGyroX()));
display.setCursor(0,12);
display.print("Y:");
display.println(abs(mpu6050.getGyroY()));
display.setCursor(0,24);
display.print("Z:");
display.println(abs(mpu6050.getGyroZ()));
display.setCursor(0,36);
display.print("ORT:");
display.println((abs(mpu6050.getGyroX())+abs(mpu6050.getGyroY())+abs(mpu6050.getGyroZ()))/3);
myRTC.updateTime();
display.setCursor(0,48);
display.print(myRTC.hours);
display.print(":");
display.print(myRTC.minutes);
display.print(" ");
display.print(myRTC.dayofmonth);
display.print("/");
display.print(myRTC.month);
display.print("/");
display.print(myRTC.year);
display.display();
if((mpu6050.getGyroX()>0,7)||(mpu6050.getGyroY()>0,7)||(mpu6050.getGyroZ()>0,7))
myFile = SD.open("kayitlar.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
myFile.print(myRTC.hours);
myFile.print(":");
myFile.print(myRTC.minutes);
myFile.print(" ");
myFile.print(myRTC.dayofmonth);
myFile.print("/");
myFile.print(myRTC.month);
myFile.print("/");
myFile.print(myRTC.year);
myFile.print(" X:");
myFile.print(mpu6050.getGyroX());
myFile.print(" Y:");
myFile.print(mpu6050.getGyroY());
myFile.print(" Z:");
myFile.println(mpu6050.getGyroZ());
// close the file:
myFile.close();
delay(10);
