ssid board name
Silly question from an Arduino newbie
From within the program, how can I retrieve the name of the board?
Thanks
Do you mean from within your own Arduino program you have coded? or from the Arduino programming program (Arduino IDE) itself?
Maybe this link could help answer both cases :stuck_out_tongue: precompiler - determine board type of Arduino - Stack Overflow
Hi
Let me explain a bit: I have an Arduino Yun which I configure it to a certain name (see this link, search under "yun name"
http://arduino.cc/en/Guide/ArduinoYun)
Now I need a way from the program to retrieve that name so I can send an intelligent msg, e..g "this is an alert from NAME_"
Thank you for taking the time to help.
I don't think you want the SSID but here is how to get it on the Linino side:
uci get wireless.@wifi-iface[0].ssid
This will show you the ssid of the wifi network the Yun is on, if the Yun is running in AP mode, this is probably what you are looking for. If the Yun is connected to another AP, like the network in your house it will show the SSID of that network.
I think you may be looking for the hostname which the Yun uses to construct it's AP mode SSID-
hostname
will give you that.
Here is a sketch which gives you both on the Leonardo side:
#include <Process.h>
  // Initialize Bridge
  Bridge.begin();
  // Initialize Serial
  // Wait until a Serial Monitor is connected.
  while (!Serial);
  runGetSSID();
  runHostname();
  // Do nothing here.
void runHostname() {
  Process p;		// Create a process and call it "p"
  p.begin("hostname");
  p.run();		// Run the process and wait for its termination
    while (p.available() > 0) {
    char c = p.read();
    Serial.print(c);
  // Ensure the last bit of data is sent.
  Serial.flush();
void runGetSSID() {
  p.begin("uci");
  p.addParameter("get");
  p.addParameter("wireless.@wifi-iface[0].ssid");
  // Print command output on the Serial.
  // A process output can be read with the stream methods
    char c = p.read();
    Serial.print(c);
  Serial.flush();
Hi noblepepper
Thanks for your help. Can't wait to try it out tonight.
Have a nice weekend noble pepper.
