I have recently developed a project for an ESP8266 to read my Google calendar and display daily reminders. My project is based on the project by Andreas Spiess here:
^GitHub - SensorsIot/Reminder-with-Google-Calender: Reminder connects an ESP8266 to a Google Calender
I am instead using a TFT display to display the time and the reminders. The project works fine on the ESP8266, but I needed more GPIO pins so decided to port it to the ESP32. This has been relatively straightforward, except that the code that fetches the calendar returns this error (obtained with debug set to 'Verbose':
Fetching events from:
https://script.google.com:/macros/s/AKfycbx7OxaWUoywhIxFxrDDcxPzzEB1Lw43SZ_WKfCN8oFVeWvXZPjwRaMrfdm21O63bH1H/exec
[ 43293][V][ssl_client.cpp:369] send_ssl_data(): Writing HTTP request with 150 bytes...
[ 43293][V][ssl_client.cpp:374] send_ssl_data(): Handling error -27136
[ 43299][E][ssl_client.cpp:37] _handle_error(): [send_ssl_data():375]: (-27136) SSL - A buffer is too small to receive or write a message
[ 43313][V][ssl_client.cpp:324] stop_ssl_socket(): Cleaning SSL connection.
Performed GET
Debug messages narrow the problem down to the following code:
HTTPSRedirect gclient;
gclient = new HTTPSRedirect(httpsPort);
gclient->setInsecure();
gclient->setPrintResponseBody(true);
gclient->setContentTypeHeader("application/json");
String calendarData = "";
//Fetch Google Calendar events
String url = String("/macros/s/") + GScriptIdRead + "/exec";
Serial.println(F("Fetching events from: "));
Serial.print("https://");
Serial.print(googleHost);
Serial.print(":");
Serial.println(url);
gclient->GET(url, googleHost);
Serial.println(F("Performed GET"));
calendarData = gclient->getResponseBody();
Serial.println(calendarData);
I am using the HTTPSRedirect library by jbuszkie as did Andreas:
This handles HTTPS re-directs such as used by Google but under the hood it boils down to a GET request being passed to the built-in ESP32 ssl_client. The URL parameter is stored as a String type and passed as const String&. The SSL library send_ssl_data() method accepts the GET request as 'sslclient_context *ssl_client'. The type sslclient_context is a struct. The GET() method seems to create the request in an appropriate format, again stored as a String type, which is then somehow passed to the ssl_client.
The sslclient_context struct is defined in terms of mbedtls objects and here is where I get rather lost.
typedef struct sslclient_context {
int socket;
mbedtls_ssl_context ssl_ctx;
mbedtls_ssl_config ssl_conf;
mbedtls_ctr_drbg_context drbg_ctx;
mbedtls_entropy_context entropy_ctx;
mbedtls_x509_crt ca_cert;
mbedtls_x509_crt client_cert;
mbedtls_pk_context client_key;
unsigned long handshake_timeout;
} sslclient_context;
SSL-Client.h:
SSL-Client.cpp
My question is, how can I increase the size of the buffer? Having looked at the source code, I can't see a specific size of buffer defined anywhere. Given how long some URL constructs can be, I find it rather odd that a URL buffer is limited to evidently less than 150 characters?
