ssue Regarding Sampling Rate of Arduino Mega and Arduino DUE
Hi, I am making a project using Arduino Mega 2560 and Arduino Due, I am converting analog signal to digital and need to know the exact sampling rate at which both the micro-controller's ADC sampled.
Is this the time for one sample because this is not the sampling rate you will achieve in practice since there are other things like doing stuff with your sampled signal and that will slow down the overall sample rate. So it is a bit of a non question.
However the last time I tested things I got:-
Due 1000 readings in 3mS in IDE 1.5.7
Due 1000 readings in 40mS in IDE 1.5.3
and The Mega I take to be 10KHz although it is slightly under.
Get the full list here:-
The EXACT sample rate is the one you choose. Show your code.
For the DUE, you can choose an ADC sampling rate up to 1 Msps.
Edit: https://gist.github.com/pklaus/5921022
ard_newbie:
No.
