ST7735 color display edges pixelated
I have these small 0,96" 80x160 color displays I want to use with ESP8266. I use arduino IDE.
Now the problem is the on the right and lower edge I see random colors, it looks like the image is shifted a few lines up and left.
I heard this was an issue with some offset in the displays and was pointed to the Bodmer ST3375 library. However that doesn't work with ESP8266
So I dove into the Arduino ST3375 library and looked at the Adafruit_ST7735.cpp file where there is a definition of Rcmd2green160x80 which is used in display initialisation. I had hoped this was the offset so I added 5 to each value to see what happend. But that didn't help, even worse, I believe it caused some crashes.
Anyone any solution?
I suspect that you have a GalaxyCore GC9106 controller.
Please post a link to the actual display that you have purchased. e.g. Ebay sale page.
David.
they are the ones from ali
like these, it ts the 0.96"variant I'm using now
Thanks for the link. My GC9106 looks exactly the same pcb, same printing !!
Run Bodmer's libraries\TFT_eSPI\examples\320 x 240\Read_ID_bitbash sketch. It should detect ID as 91 06
You can try my (non-public) https://github.com/prenticedavid/Adafruit_GC9102_kbv library
David.
