Finally the below code solved my problem (Some mejor modification needed
#include <SPI.h>
#include <Adafruit_GFX.h>
#include "RREFont.h"
#include "rre_fjg_8x16.h"
#include "rre_5x8.h"
#define TFT_CS 8
#define TFT_RST 7
#define TFT_DC 6
#define SCR_WD 128
#define SCR_HT 160
// use 3 debouncing capacitors (100nF seems to be enough)
#define encoderPinA 4
#define encoderPinB 3
#define encoderButton 2
#include <Arduino_ST7735_Fast.h>
Arduino_ST7735 lcd = Arduino_ST7735(TFT_DC, TFT_RST, TFT_CS);
RREFont font;
// needed for RREFont library initialization, define your fillRect
void customRect(int x, int y, int w, int h, int c) {
return lcd.fillRect(x, y, w, h, c);
#include <EEPROM.h>
volatile int encoderPos = 0, encoderPosOld = 0, encoderStep = 2;
void initEncoder()
encoderPos = 0;
pinMode(encoderPinA, INPUT_PULLUP);
pinMode(encoderPinB, INPUT_PULLUP);
pinMode(encoderButton, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(encoderPinA), readEncoderInt, CHANGE); // encoder pin on interrupt 0 = pin 2
attachInterrupt(digitalPinToInterrupt(encoderButton), buttonInt, CHANGE); // encoder pin on interrupt 1 = pin 3
void buttonInt() {}
void readEncoderInt()
//(digitalRead(encoderPinA) == digitalRead(encoderPinB)) ? encoderPos++ : encoderPos--;
uint8_t pd = PIND & B10100; // inputs #2 and #4 direct reading
((pd == B10100) || (pd == B00000)) ? encoderPos++ : encoderPos--;
int readButton()
const long btDebounce = 30;
static long btTime = 0;
static int lastState = HIGH;
int val = 0, state = digitalRead(encoderButton);
if (state == LOW && lastState == HIGH) {
btTime = millis();
val = 0;
if (state == HIGH && lastState == LOW && millis() - btTime >= btDebounce) {
val = 1;
lastState = state;
return val;
long readVcc()
long result;
// Read 1.1V reference against AVcc
ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
delay(2); // Wait for Vref to settle
ADCSRA |= _BV(ADSC); // Convert
while (bit_is_set(ADCSRA, ADSC));
result = ADCL;
result |= ADCH << 8;
result = 1125300L / result; // Back-calculate AVcc in mV
return result;
float readIntTemp()
long result;
// Read temperature sensor against 1.1V reference
ADMUX = _BV(REFS1) | _BV(REFS0) | _BV(MUX3);
delay(5); // Wait for Vref to settle
result = ADCL;
result = (result - 125) * 1075;
return result / 10000.0;
#define MAXSIN 255
const uint8_t sinTab[91] PROGMEM = {
0, 4, 8, 13, 17, 22, 26, 31, 35, 39, 44, 48, 53, 57, 61, 65, 70, 74, 78, 83, 87, 91, 95, 99, 103, 107, 111, 115, 119, 123,
127, 131, 135, 138, 142, 146, 149, 153, 156, 160, 163, 167, 170, 173, 177, 180, 183, 186, 189, 192, 195, 198, 200, 203, 206, 208, 211, 213, 216, 218,
220, 223, 225, 227, 229, 231, 232, 234, 236, 238, 239, 241, 242, 243, 245, 246, 247, 248, 249, 250, 251, 251, 252, 253, 253, 254, 254, 254, 254, 254,
255
int fastSin(int i)
while (i < 0) i += 360;
while (i >= 360) i -= 360;
if (i < 90) return (pgm_read_byte(&sinTab[i])); else if (i < 180) return (pgm_read_byte(&sinTab[180 - i])); else if (i < 270) return (-pgm_read_byte(&sinTab[i - 180])); else
return (-pgm_read_byte(&sinTab[360 - i]));
int fastCos(int i)
return fastSin(i + 90);
char buf[100];
void drawGauge1(int level)
int sx, sy, xs0, ys0, xe0, ye0, xs1, ys1, xe1, ye1;
int cx = SCR_WD / 2;
int cy = SCR_HT / 2;
int rx0 = 40, ry0 = 40;
int rx1 = 63, ry1 = 63;
int mina = -60;
int maxa = 180 + 60;
for (int i = mina; i < maxa; i += 15) { // 22 pieces
sx = fastCos(i - 180);
sy = fastSin(i - 180);
xs0 = cx + sx * rx0 / MAXSIN;
ys0 = cy + sy * ry0 / MAXSIN;
xe0 = cx + sx * rx1 / MAXSIN;
ye0 = cy + sy * ry1 / MAXSIN;
sx = fastCos(i - 180 + 10);
sy = fastSin(i - 180 + 10);
xs1 = cx + sx * rx0 / MAXSIN;
ys1 = cy + sy * ry0 / MAXSIN;
xe1 = cx + sx * rx1 / MAXSIN;
ye1 = cy + sy * ry1 / MAXSIN;
int l = 20 * (i - mina) / (maxa - mina);
uint16_t c = (l < level) ? lcd.rgbWheel(512L * l / 20) : RGBto565(60, 60, 60);
lcd.fillTriangle(xs0, ys0, xe0, ye0, xe1, ye1, c);
lcd.fillTriangle(xs1, ys1, xe1, ye1, xs0, ys0, c);
snprintf(buf, 10, "%02d", level);
font.setColor(WHITE, BLACK);
font.printStr(ALIGN_CENTER, SCR_HT / 2 - 7, buf);
char *menuTxt[] = {
"Set value", // 0
"Help", // 1
"MCU Temp", // 2
"VCC/Battery", // 3
"EEPROM dump", // 4
"Graph", // 5
"Bckgrnd color", // 6
"Item color", // 7
"Frame color", // 8
"Slider color", // 9
"About", // 10
"Reboot" // 11
const int itemHt = 20;
const int numMenus = sizeof(menuTxt) / sizeof(char*);
const int numScrLines = SCR_HT / itemHt; // 160/20=8
int menuSel = 0, menuSelOld = 0;
int menuStart = 0;
int menuMode = -1; // -1 -> menu of options, 0..n -> option
int storedPos = 0;
uint16_t bgCol = RGBto565(30, 30, 140);
uint16_t frameCol = RGBto565(255, 255, 40);
uint16_t itemCol = RGBto565(220, 220, 220);
uint16_t sliderCol = RGBto565(20, 180, 180);
void showHelp()
lcd.fillScreen(RGBto565(150, 0, 0));
font.setColor(WHITE);
font.printStr(ALIGN_CENTER, 4, "Help");
font.setColor(YELLOW);
font.setCR(1);
font.setCharMinWd(0);
font.printStr(5, 24, "Use encoder to select menu item.\nPress button to exit.");
font.setCR(0);
void showSelected(char *txt)
lcd.fillScreen(RGBto565(150, 0, 150));
font.printStr(10, 10, "Selected:");
font.printStr(10, 30, txt);
void printMenuItem(int y, char *item)
font.setColor(itemCol);
font.printStr(3, 2 + y * itemHt, item);
void printMenu(int full = 0)
int n = numMenus < numScrLines ? numMenus : numScrLines;
for (int i = 0; i < n; i++) {
formatMenu(menuTxt[i + menuStart], buf, 14);
full ? lcd.fillRect(0, i * itemHt, SCR_WD, itemHt, bgCol) : lcd.fillRect(3, 2 + i * itemHt, 120 - 4, 16, bgCol);
printMenuItem(i, buf);
void setMenu(int m)
menuMode = m;
storedPos = encoderPos;
encoderPos = 0;
void endMenu(int butt)
if (!butt) return;
menuMode = -1;
initMenu();
encoderPos = storedPos;
void formatMenu(char *in, char *out, int num)
int j = strlen(in);
strncpy(out, in, j);
for (; j < num; j++) out[j] = ' ';
out[j] = 0;
void drawMenuSlider()
//int ht = 10;
int ht = (SCR_HT - 4) / numMenus;
int n = (SCR_HT - 4 - ht) * menuSel / (numMenus - 1);
lcd.drawRect(SCR_WD - 6, 0, 6, SCR_HT, sliderCol);
lcd.fillRect(SCR_WD - 6 + 2, 2, 2, SCR_HT - 4, bgCol);
lcd.fillRect(SCR_WD - 6 + 2, n + 2, 2, ht, sliderCol);
void drawFrame(int sel, int stat)
lcd.drawRect(0, (sel - menuStart)*itemHt, 120, itemHt - 1, stat ? frameCol : bgCol);
void initMenu()
font.setFont(&rre_fjg_8x16);
font.setCharMinWd(8);
font.setSpacing(1);
printMenu(1);
drawMenuSlider();
drawFrame(menuSel, 1);
void setValue()
if (encoderPos < 0) encoderPos = 0;
if (encoderPos > 40) encoderPos = 40;
drawGauge1(encoderPos / encoderStep);
int colR, colG, colB;
int colRold, colGold, colBold;
int setRGBMode = 0;
int colBarWd = 96;
int colBarY0 = 5;
int colBarY = 40;
int colBarHt = 30;
int encoderMin = 0;
int encoderMax = 255;
void setColorInit(uint16_t *c)
colR = (*c & 0xf800) >> 8;
colG = (*c & 0x7e0) >> 3;
colB = (*c & 0x1f) << 3;
colRold = colGold = colBold = 0;
lcd.fillScreen(BLACK);
for (int i = 0; i < 32; i++) { // 96 pixels wide, 32 shades
lcd.fillRect(2 + i * 3, colBarY0 + colBarY * 0, 3, colBarHt, RGBto565(i * 8, 0, 0));
lcd.fillRect(2 + i * 3, colBarY0 + colBarY * 1, 3, colBarHt, RGBto565(0, i * 8, 0));
lcd.fillRect(2 + i * 3, colBarY0 + colBarY * 2, 3, colBarHt, RGBto565(0, 0, i * 8));
lcd.drawRect(1, colBarY0 + colBarY * 0 - 1, colBarWd + 2, colBarHt + 2, RGBto565(128, 0, 0));
lcd.drawRect(1, colBarY0 + colBarY * 1 - 1, colBarWd + 2, colBarHt + 2, RGBto565(0, 128, 0));
lcd.drawRect(1, colBarY0 + colBarY * 2 - 1, colBarWd + 2, colBarHt + 2, RGBto565(0, 0, 128));
lcd.fillRect(128 - 50 - 2, 160 - 25 - 2, 50, 25, *c); // cancel
encoderMax = 4;
void setColorAction(uint16_t *col, int butt)
if (encoderPos < encoderMin * encoderStep) encoderPos = encoderMin * encoderStep;
if (encoderPos > encoderMax * encoderStep) encoderPos = encoderMax * encoderStep;
int pos = encoderPos / encoderStep;
int frw = 2 + 96 + 2;
if (butt) {
if (setRGBMode > 0) {
encoderStep = 2;
encoderPos = (setRGBMode - 1) * encoderStep;
setRGBMode = 0;
encoderMax = 4;
if (pos == 3 || pos == 4) {
if (pos == 3) *col = RGBto565(colR, colG, colB);
menuMode = -1;
initMenu();
setRGBMode = 0;
encoderStep = 2;
return;
setRGBMode = pos + 1;
encoderMax = 255;
encoderStep = 1;
if (setRGBMode == 1) {
encoderPos = colR;
lcd.drawRect(0, colBarY0 + colBarY * 0 - 2, frw, colBarHt + 4, RGBto565(255, 80, 80));
} else if (setRGBMode == 2) {
encoderPos = colG;
lcd.drawRect(0, colBarY0 + colBarY * 1 - 2, frw, colBarHt + 4, RGBto565(80, 255, 80));
} else if (setRGBMode == 3) {
encoderPos = colB;
lcd.drawRect(0, colBarY0 + colBarY * 2 - 2, frw, colBarHt + 4, RGBto565(80, 80, 255));
return;
if (setRGBMode == 1) colR = pos; else if (setRGBMode == 2) colG = pos; else if (setRGBMode == 3) colB = pos;
int xcol = 128 - 9 * 3 + 1;
if (setRGBMode == 0 || setRGBMode == 1) {
dtostrf(colR, 3, 0, buf);
font.printStr(xcol, colBarY0 + colBarY * 0 + 8, buf);
if (setRGBMode == 0 || setRGBMode == 2) {
dtostrf(colG, 3, 0, buf);
font.printStr(xcol, colBarY0 + colBarY * 1 + 8, buf);
if (setRGBMode == 0 || setRGBMode == 3) {
dtostrf(colB, 3, 0, buf);
font.printStr(xcol, colBarY0 + colBarY * 2 + 8, buf);
if (colRold != colR) {
lcd.drawFastVLine(2 + 3 * colRold / 8, colBarY0 + colBarY * 0, colBarHt, RGBto565(colRold, 0, 0));
lcd.drawFastVLine(2 + 3 * colR / 8, colBarY0 + colBarY * 0, colBarHt, YELLOW);
colRold = colR;
if (colGold != colG) {
lcd.drawFastVLine(2 + 3 * colGold / 8, colBarY0 + colBarY * 1, colBarHt, RGBto565(0, colGold, 0));
lcd.drawFastVLine(2 + 3 * colG / 8, colBarY0 + colBarY * 1, colBarHt, YELLOW);
colGold = colG;
if (colBold != colB) {
lcd.drawFastVLine(2 + 3 * colBold / 8, colBarY0 + colBarY * 2, colBarHt, RGBto565(0, 0, colBold));
lcd.drawFastVLine(2 + 3 * colB / 8, colBarY0 + colBarY * 2, colBarHt, YELLOW);
colBold = colB;
lcd.fillRect( 2, 160 - 25 - 2, 50, 25, RGBto565(colR, colG, colB)); // ok
if (setRGBMode == 0) {
lcd.drawRect(0, colBarY0 + colBarY * 0 - 2, frw, colBarHt + 4, BLACK);
lcd.drawRect(0, colBarY0 + colBarY * 1 - 2, frw, colBarHt + 4, BLACK);
lcd.drawRect(0, colBarY0 + colBarY * 2 - 2, frw, colBarHt + 4, BLACK);
lcd.drawRect( 0, 160 - 25 - 4, 50 + 4, 25 + 4, BLACK);
lcd.drawRect(128 - 50 - 4, 160 - 25 - 4, 50 + 4, 25 + 4, BLACK);
switch (pos) {
case 0: lcd.drawRect(0, colBarY0 + colBarY * 0 - 2, frw, colBarHt + 4, WHITE); break;
case 1: lcd.drawRect(0, colBarY0 + colBarY * 1 - 2, frw, colBarHt + 4, WHITE); break;
case 2: lcd.drawRect(0, colBarY0 + colBarY * 2 - 2, frw, colBarHt + 4, WHITE); break;
case 3: lcd.drawRect( 0, 160 - 25 - 4, 50 + 4, 25 + 4, WHITE); break;
case 4: lcd.drawRect(128 - 50 - 4, 160 - 25 - 4, 50 + 4, 25 + 4, WHITE); break;
uint16_t reqBgCol = RGBto565(0, 80, 0);
int reqY = 110;
void reqInit()
lcd.fillScreen(reqBgCol);
font.printStr(ALIGN_CENTER, 50, "Are you sure?");
font.printStr(8, reqY, " OK ");
font.printStr(ALIGN_RIGHT, reqY, " CANCEL ");
void reqAction()
if (encoderPos > 1 * encoderStep) encoderPos = 1 * encoderStep;
lcd.drawRect(8, reqY - 3, 4 * 9 - 2, 20, reqBgCol);
lcd.drawRect(128 - 8 * 9, reqY - 3, 8 * 9 - 4, 20, reqBgCol);
if (pos == 0) lcd.drawRect(8, reqY - 3, 4 * 9 - 2, 20, WHITE); else if (pos == 1) lcd.drawRect(128 - 8 * 9, reqY - 3, 8 * 9 - 4, 20, WHITE);
void showBattery()
char flt[10];
long v = readVcc();
dtostrf(v / 1000.0, 1, 3, flt);
snprintf(buf, 90, "Vcc=%sV", flt);
font.printStr(16, 30, buf);
lcd.drawRect(10, 60, 128 - 20 - 8, 50, WHITE);
lcd.fillRect(10 + 128 - 20 - 8, 60 + 15, 8, 20, WHITE);
int bwd = 128 - 20 - 8 - 8l;
uint16_t c = YELLOW;
if (v > 3600) c = GREEN;
if (v < 3100) c = RED;
long fill = constrain(map(v, 2900, 4200, 0, bwd - 10), 0, bwd - 10);
lcd.fillRect(14, 64, fill + 10, 50 - 8, c);
void showIntTemp()
char flt[10];
dtostrf(readIntTemp(), 2, 1, flt);
snprintf(buf, 90, "Temp=%s'C", flt);
font.printStr(ALIGN_CENTER, 70, buf);
void dumpEEPROM()
//font.setFont(&rre_4x7); font.setCharMinWd(4);
font.setFont(&rre_5x8); font.setCharMinWd(5);
if (encoderPos >= (128 - 16) * 2) encoderPos = (128 - 16) * 2;
int st = encoderPos / encoderStep;
for (int j = 0; j < 16; j++) {
int ii = st * 8 + j * 8;
ii &= 0x3ff; // max 1kB
snprintf(buf, 8, "%03X", ii);
font.setColor(YELLOW, BLACK);
font.printStr(0, j * 10, buf);
for (int i = 0; i < 8; i++) {
int v = EEPROM.read(ii + i);
snprintf(buf, 8, "%02X", v);
font.printStr(5 * 4 + 2 + i * 13, j * 10, buf);
void menuItemInit()
setMenu(menuSel);
switch (menuMode) {
case 0: lcd.fillScreen(BLACK); encoderPos = 5 * encoderStep; break; // for setValue()
case 1: showHelp(); break;
case 2: showIntTemp(); break;
case 3: showBattery(); break;
case 4: lcd.fillScreen(BLACK); break; // for dumpEEPROM()
case 6: setColorInit(&bgCol); break;
case 7: setColorInit(&itemCol); break;
case 8: setColorInit(&frameCol); break;
case 9: setColorInit(&sliderCol); break;
case 11: reqInit(); break;
default: showSelected(menuTxt[menuSel]);
void menuItemAction(int butt)
switch (menuMode) {
case 0: setValue(); endMenu(butt); break;
case 4: dumpEEPROM(); endMenu(butt); break;
case 6: setColorAction(&bgCol, butt); break;
case 7: setColorAction(&itemCol, butt); break;
case 8: setColorAction(&frameCol, butt); break;
case 9: setColorAction(&sliderCol, butt); break;
case 11: reqAction(); endMenu(butt); break;
default: endMenu(butt);
void handleMenu()
int butt = readButton();
if (encoderPosOld == encoderPos && !butt) return;
encoderPosOld = encoderPos;
if (menuMode == -1) {
menuSel = encoderPos / encoderStep;
if (menuSel >= numMenus) {
menuSel = numMenus - 1;
encoderPos = menuSel * encoderStep;
if (menuSel >= menuStart + numScrLines) {
menuStart = menuSel - numScrLines + 1;
printMenu();
if (menuSel < menuStart) {
menuStart = menuSel;
printMenu();
if (menuSelOld != menuSel) {
drawFrame(menuSelOld, 0);
drawMenuSlider();
menuSelOld = menuSel;
if (butt) menuItemInit();
} else menuItemAction(butt);
lcd.init();
//lcd.fillScreen(bgCol);
font.init(customRect, SCR_WD, SCR_HT); // custom fillRect function and screen width and height values
initEncoder();
initMenu();
handleMenu();
