St7739 1.44 lcd oscilloscope
#include <Adafruit_ST7735.h>
#include <SPI.h>
// 定义TFT LCD引脚
#define TFT_SCLK 13  // SCL
#define TFT_MOSI 11  // SDA
#define TFT_RST  9   // RES
#define TFT_DC   8   // DC
#define TFT_CS   10  // CS
// 定义按钮引脚
#define BUTTON_PIN 2
// 创建TFT LCD对象
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
// 定义输入引脚
const int inputPin = A0;
bool isRunning = false;
  // 设置按钮引脚为输入模式
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  // 设置SPI时钟频率
  SPI.setClockDivider(SPI_CLOCK_DIV16); // 1 MHz
  // 初始化TFT LCD
  tft.initR(INITR_BLACKTAB);
  tft.setRotation(1);
  tft.fillScreen(ST7735_BLACK);
  tft.setTextColor(ST7735_WHITE);
  tft.setTextSize(1);
  tft.setCursor(0, 0);
  tft.println("Oscilloscope");
  // 检查按钮状态
  if (digitalRead(BUTTON_PIN) == LOW) {
    isRunning = !isRunning;
    delay(200); // 防止按钮抖动
  if (isRunning) {
    // 读取输入引脚的值
    int value = analogRead(inputPin);
    // 清空TFT LCD
    // 绘制波形
    for (int x = 0; x < 144; x++) {
      int y = map(value, 0, 1023, 0, 159);
      tft.drawPixel(x, y, ST7735_WHITE);
      delayMicroseconds(1); // 将采样频率设置为 1 MHz
    tft.setCursor(0, 20);
    tft.println("Press button to start");
As your topic does not relate directly to the installation or operation of the IDE it has been moved to the Programming Questions category of the forum
Do you have a question relating to the code that you posted ?
YES it is
Sorry but I don't understand what you are saying
I repeat, do you have a question about the code that you posted ?
yes it's not correct
We are making slow progress because you are not providing good information
  • Which Arduino board are you using ?
  • Does the code compile ?
  • If it compiles what does it do or not do ?
NANO
Yes
It's can't Detect high HZ
What is your definition of high frequency in this case ?
#include <SPI.h>
// 创建TFT LCD对象                     CS, DC, MOSI, SCLK, RST
Adafruit_ST7735 tft = Adafruit_ST7735 (10,  8,   11,   13,   9);
// 定义输入引脚
const byte BUTTON_PIN = 2;
      byte butState;
const int BufSize = 144;
      int buf [BufSize];
void loop ()
    byte but = digitalRead (BUTTON_PIN);
    if (butState != but) {              // change
        butState = but;
        delay (20);                     // debounce
        if (LOW == but)
    if (! isRunning)
        return;
    // capture samples -- max ~10000/sec
    for (int n = 0; n < BufSize; n++)
        buf [n] = analogRead (inputPin);
    // display samples
    tft.fillScreen (ST7735_BLACK); // 清空TFT LCD
    for (int n = 0; n < BufSize; n++)  {
        int y = map (buf [n], 0, 1023, 0, 159);
        tft.drawPixel (n, y, ST7735_WHITE);
void setup () {
    // 设置按钮引脚为输入模式
    pinMode (BUTTON_PIN, INPUT_PULLUP);
    butState = digitalRead (BUTTON_PIN);
    // 设置SPI时钟频率
    SPI.setClockDivider (SPI_CLOCK_DIV16); // 1 MHz
    // 初始化TFT LCD
    tft.initR         (INITR_BLACKTAB);
    tft.setRotation   (1);
    tft.setTextColor (ST7735_WHITE);
    tft.setTextSize  (1);
    tft.setCursor    (0, 0);
    tft.println ("Oscilloscope");
