Hi.
I using ST7920 and Arduino nano. . I used the u8g library and its commands to launch ST7920+Arduino Nano . The problem I have is that when I run the code, everything is displayed correctly at first, but after a few minutes, the image shifts to one side, and the problem is solved only by disconnecting the power supply or resetting the LCD reset pin, but after a few minutes this problem repeats again.
my code:
//========== LCD ST7920 ========== Begin
#include "U8glib.h"
//U8GLIB_ST7920_128X64_4X u8g(10);
//U8GLIB_ST7920_128X64_1X u8g(10);
U8GLIB_ST7920_128X64 u8g(13, 11, 10, U8G_PIN_NONE); // SPI Com: SCK = en = 13, MOSI = rw = 11, CS = di = 0
//========== LCD ST7920 ========== End
//========= Buzzer ========== Begin
const int BuzzerPin =12 ; // Buzzer
//========= Buzzer ========== End
//========= Thermometr-Max6675 ========== Begin
#include <max6675.h>
const char DEGREE_SYMBOL[] = { 0xB0, '\0' };
int soPin1 = 4;// SO=Serial Out
int csPin1 = 5;// CS = chip select CS pin
int sckPin1 = 6;// SCK = Serial Clock pin
MAX6675 thermocouple1(sckPin1, csPin1, soPin1);// create instance object of MAX6675
int soPin2 = 7;// SO=Serial Out
int csPin2 = 8;// CS = chip select CS pin
int sckPin2 = 9;// SCK = Serial Clock pin
MAX6675 thermocouple2(sckPin2, csPin2, soPin2);// create instance object of MAX6675
int Temp1,Temp2; // Thermostate Tempretures(Degree Celeciuse)
//========= Thermometr-Max6675 ========== End
//========= Rotary Encoder ========== Begin
int encoder_clockP = A2;
int encoder_data = A1;
int encoder_switch=A0;
int encoder_count = 0;
int c = HIGH;
int cLast = HIGH;
int d = HIGH;
//========= Rotary Encoder ========== End
//-------------------------- Global Variables --------------------------------
int Digit1_Min1_Set=0,Digit2_Min1_Set=0,Digit1_Sec1_Set=0,Digit2_Sec1_Set=0; //Timer 1 Min. and Sec. Setting for Operation
int Digit1_Min2_Set=0,Digit2_Min2_Set=0,Digit1_Sec2_Set=0,Digit2_Sec2_Set=0; //Timer 2 Min. and Sec. Setting for Operation
int TempSet1,TempSet2; //Temp. Setting for Operation
int CycleNo=0;
//-------------------------- Other Functions ---------------------------------
//DisplayData
void DisplayData(){
unsigned long tik_mili=1000;
u8g.firstPage();
do {
u8g.drawFrame(1,2,126,62);
u8g.drawLine(62,2,62,62);
u8g.drawLine(1,25,126,25);
u8g.setFont(u8g_font_6x10);
//-------------- temp -----------
u8g.drawStr( 20, 18, "Temp");
u8g.setPrintPos(07,38);
u8g.print(Temp1);
//u8g.drawStr( 07, 38,char(Temp1));
u8g.drawStr( 48, 38, DEGREE_SYMBOL);
u8g.drawStr( 53, 38, "C");
u8g.setPrintPos(07,58);
u8g.print(Temp2);
//u8g.drawStr( 07, 58,"000.00");// Temp2);
u8g.drawStr( 48, 58, DEGREE_SYMBOL);
u8g.drawStr( 53, 58, "C");
//--------------time ------------
u8g.drawStr( 83, 18, "Time");
u8g.drawStr( 70, 38, "00");
u8g.drawStr( 91, 38, ":");
u8g.drawStr( 102, 38, "00");
u8g.drawStr( 70, 58, "00");
u8g.drawStr( 91, 58, ":");
u8g.drawStr( 102, 58, "00");
} while( u8g.nextPage() );
//delay(1000);
//clearLCD();
//ClearLCD
void clearLCD(){
u8g.firstPage();
do {
//------- read Termocuple function -------
void ReadTemperature()
Temp1=thermocouple1.readCelsius();
Temp2=thermocouple2.readCelsius();
//------- Get Timers Setting function -------
void GetTimeSetting(){
GetTimeSettingDisplay(8);
//------- Get Timers Setting Display function -------
void GetTimeSettingDisplay(int mode){
int x,y; //frame around of selected digit
int fcolor[8];
for (int i=0;i<8;i++) {
fcolor[i]=0;
fcolor[mode-1]=1;
switch(mode){
case 2:
x=63;
y=29;
case 3:
x=77;
y=29;
case 4:
x=84;
y=29;
case 5:
x=56;
y=49;
case 6:
x=63;
y=49;
case 7:
x=77;
y=49;
case 8:
x=84;
y=49;
default:
x=56;
y=29;
u8g.firstPage();
do {
u8g.drawBox(x,y,9,11);
u8g.drawStr( 7, 18, "Enter Time Settings");
u8g.DefaultForegroundColor(0);
u8g.print("Time1:");
u8g.setPrintPos( 58, 38);
u8g.DefaultForegroundColor(fcolor[1-1]);
u8g.print(String(Digit1_Min1_Set));
u8g.setPrintPos( 65, 38);
u8g.DefaultForegroundColor(fcolor[2-1]);
u8g.print(String(Digit2_Min1_Set));
u8g.setPrintPos( 72, 38);
u8g.print(":");
u8g.setPrintPos( 79, 38);
u8g.DefaultForegroundColor(fcolor[3-1]);
u8g.print(String(Digit1_Sec1_Set));
u8g.setPrintPos( 86, 38);
u8g.DefaultForegroundColor(fcolor[4-1]);
u8g.print(String(Digit2_Sec1_Set));
u8g.print("Time2:");
u8g.setPrintPos( 58, 58);
u8g.DefaultForegroundColor(fcolor[5-1]);
u8g.print(String(Digit1_Min2_Set));
u8g.setPrintPos( 65, 58);
u8g.DefaultForegroundColor(fcolor[6-1]);
u8g.print(String(Digit2_Min2_Set));
u8g.setPrintPos( 72, 58);
u8g.print(":");
u8g.setPrintPos( 79, 58);
u8g.DefaultForegroundColor(fcolor[7-1]);
u8g.print(String(Digit1_Sec2_Set));
u8g.setPrintPos( 86, 58);
u8g.DefaultForegroundColor(fcolor[8-1]);
u8g.print(String(Digit2_Sec2_Set));
//------- Get Temp. Setting function -------
void GetTempSetting(){
//-------------------------- Main Functions ---------------------------------
//------- SETUP function -------Begin
// assign default color value
if ( u8g.getMode() == U8G_MODE_R3G3B2 ) {
u8g.setColorIndex(255); // white
else if ( u8g.getMode() == U8G_MODE_GRAY2BIT ) {
u8g.setColorIndex(3); // max intensity
else if ( u8g.getMode() == U8G_MODE_BW ) {
u8g.setColorIndex(1); // pixel on
else if ( u8g.getMode() == U8G_MODE_HICOLOR ) {
u8g.setHiColorByRGB(255,255,255);
//========== Buzzer pin setting ========== begin
pinMode(BuzzerPin,OUTPUT);
//========== Buzzer pin setting ========== end
//========== Rotary Encoder ========== begin
pinMode (encoder_clockP,INPUT_PULLUP);
pinMode (encoder_data,INPUT_PULLUP);
pinMode (encoder_switch,INPUT_PULLUP);
//========== Rotary Encoder ========== end
clearLCD();
CycleNo=0;
//------- SETUP function -------End
//------- LOOP function -------Begin
if(CycleNo<13){
GetTimeSetting();
GetTempSetting();
}else
ReadTemperature();
DisplayData();
