ST9720 in serial mode - how to wire?
dc42: Another solution for the LCD might be a ST7920-based 128x64 graphic LCD, which needs only 2 pins to drive it.
I'm resurrecting an old thread.... What's the correct wiring for the ST9720 based displays in serial mode? What pins do I have to connect?
A quick Google search turned up http://parenthetic.blogspot.com/2011/12/hello-world-in-arduino-with-st7920-lcd.html
In this case (only using Clock and MOSI) you can use shiftOut() in place of the SPI hardware.
Thanks. I saw that earlier but I missed the part in the source where he has the pins.
Is there a library that can use these? glcd? dfrobot has an arduino library for serial, but I guess I’m looking for something more “official” - and also better documented.
http://www.dfrobot.com/index.php?route=product/product&product_id=240
http://code.google.com/p/u8glib/
Oliver
olikraus: http://code.google.com/p/u8glib/
Oliver
Thank you!
