Hi, I´ve just make a control pressure in a balloon with a pump and a servo to open a valve connected in a arduino mini. I put the Set Up pressure that I want and the balloon float up in the air. The problem is that it has not stability and it stops often suddenly and i have to reset again and again. Please how can I fix the problem and get a stable instalation? Thank you very much.
Start with the two links below please as there is not enough information to proceed.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
