Hello,
This is the second time I have posted about this problem, I am trying to be as clear as possible and I appreciate any help. I am using two shields
Wireless SD shield
LCD Keypad Shield
with an Arduino mega 2560. I have already discovered the problem with digital pin 4, being used as the chip select for the SD card and as one of the data pins for the LCD pin. I changed the pin on the LCD shield to another digital pin and changed the the code to
LiquidCrystal lcd(8, 9, 52, 5, 6, 7);
I have looked and have not found anymore interferences, but I could have missed it.
I am unable to write to the sd card at the same time as displaying a message on the LCD. I don't think the problem lies with the XBee, as I am able to receive data from the XBee and display it to the LCD if I do not use the SD card.
When I do have the SD/LCD shields both plugged into the mega the characters on the LCD are incorrect. Instead of "SELECT" it displays "BDLDBD". When I made a custom character, just a plain box, it worked fine. Also, lcd.clear(); does not work. I am really at a loss and would appreciate any help.
If I am missing something or am unclear in a description just tell me.
