Stainless Band Heater
Hey
I used to use
220V Voltage 110W Stainless Band Heater
30mm in diameter (as pictured) and I am very pleased with it.
But now I need the same heater but with a diameter of 10 MM
Is it achievable and is there alternative hardware?
Thank you very much.
A quick Google indicated that small diameter heaters are difficult to find: I drilled down into a large Chinese site and did not see your need in a standard size:
https://www.superbheater.com/heaters/band-heaters/5x30mm-35x35mm-35x40mm-mica-band-heater.html
The above link indicates custom sizes are available, but I doubt in a quantity of one or two. eMail them if you wish.
Hot Tags: 5x30mm 35x35mm 35x40mm Mica Band Heater Stainless Steel 110V 220V 380V 35mm Inside Dia. Electric Heating Element manufacturers, suppliers, factory
Thank you.
Do you know a good replacement?
