I am making an apparatus to convert 8mm cine films into a digital form. Its all been done before but its new to me. It involes taking a still photograph of every single frame of the cine film, I am aiming for 3 frames per second. Then other PC based software is used to turn these into a movi.
I will use a heavily modified old projector to transport the film through the gate. The original motor will be replaced with a DC motor driven via an H bridge and the lamp will be relaced by an 8 watt COB LED. A still camera is mounted outside the projector and is focused on the film gate. The whole lot will be controlled by an arduino.
A small magnet is fitted to the shutter blade within the projector which passes a hall sensor every time a new frame of cine film is ready in the gate.
I will use a PC based program to take the pictures. This part is a bit hairy. The pic is taken by clicking a button on the GUI. I have modified a mouse to take the signal from the arduino every time the hall sensor senses the magnet. (so the mouse acts like a left click). So before starting the process I have to position the mouse arrow so that it is over the "button".
The COB LED gets very hot if it is permanently on, even with a big heatsink. So I intend to switch it on only when needed. The power to the LED is also a PWM feed so that I can adjust the exposure.
The PC program seems to need a 15mS pulse to start taking the photo so my sequence is:-
magnet detected
send 15mS pulse to the mouse and turn on LED
wait another 15mS while the picture is taken
wait another 15mS for good measure
switch off LED
wait for the next magnet detection
The arduino will eventually control the motor as well but at the moment I am working only on the Capture (Trigger pulse) and the control of the LED (strobe pulse)
I have dabbled in arduino stuff before but to be honest, I have made too big a jump this time. The milli stuff is doing my head in. I have started using serial.Print to try and debug but my brain is not big enough to process the evidence that I am seeing.
I can see that the capPin is HIGH when needed but I see no response from the strobe.
My code
const byte ledPwmPin = 6;
const int potPin = A0;
const int capPin = 13;
const int hallPin = 2;
int output;
int ledValue;
unsigned long startMillis; //some global variables available anywhere in the program
unsigned long currentMillis;
unsigned long startTrigger;
unsigned long endTrigger;
unsigned long endStrobe;
const unsigned long triggerPulseDuration = 15; //the value is a number of milliseconds
const unsigned long strobeOnDuration = 45; //the value is a number of milliseconds
volatile byte val = LOW;
volatile byte valCap = HIGH;
Serial.begin(115200); //start Serial in case we need to print debugging info
startMillis = millis(); //initial start time
pinMode(ledPwmPin, OUTPUT);
pinMode(capPin, OUTPUT);
pinMode(hallPin, INPUT);
pinMode(potPin, INPUT);
currentMillis = millis();
startTriggerPulseAndStrobe();
endTriggerPulse();
stopStrobe();
void startTriggerPulseAndStrobe()
val = digitalRead(hallPin);
Serial.print("val = ");
Serial.println(val);
if (currentMillis - startMillis >= triggerPulseDuration && val == LOW)
digitalWrite(capPin, HIGH);
valCap = digitalRead(capPin);
Serial.print("valCap = ");
Serial.println(valCap);
startTrigger = millis();
//Reading from potentiometer
output = analogRead(potPin);
//Mapping the Values between 0 to 255
//from 0 -255 using the analogwrite funtion
ledValue = map(output, 0, 1023, 0, 255);
analogWrite(ledPwmPin, ledValue);
void endTriggerPulse()
endTrigger = millis();
if (endTrigger - startTrigger >= triggerPulseDuration) //test whether the triggerPulseDuration has elapsed
digitalWrite(capPin, LOW);
void stopStrobe()
endStrobe = millis();
if (endStrobe - startMillis >= strobeOnDuration)
analogWrite(ledPwmPin, 0);
Can someone give me some pointer on what I am doing wrong with the millis, probably many things?
Also
I suspect that the trigger pulse is being sent multiple times during the relatively long period that the magnet passes the hall sensor. I need to prevent this.
Many thanks in anticipation
