Stand alone adalight-like power supply
Hello everybody
I've done the Overview | Adalight Project Pack | Adafruit Learning System project for my PC
I got a spare LED strip and i plan to make a stand alone version for a mood lighting in my house
LED strip is this one 12mm Diffused Flat Digital RGB LED Pixels (Strand of 25) [WS2801] : ID 738 : $39.95 : Adafruit Industries, Unique & fun DIY electronics and kits 25 LED, 5 V, 60 mA per LED (1.5 A total max)
My questions is what kind of power supply wiring should I do :
  1. use a 5 V, 2 A power supply to the arduino and then use the Vin and GND pin to supply the LED strip
  2. use a 12 V, 2 A power supply to the arduino and then use the +5 V and GND pin to supply the LED strip
  3. use a 5 V, 2 A power supply the breadboard and from it supply the LED strip and the arduino (with Vin / GND pin)
thanks for your advices
Yes this way you will have the leftover current @ 5v from a 5v 2amp wallwart in VIN ,leftover current because very small value in mA's is utilised by the Arduino itself which consumption becomes somewhat high as the Voltage regulator's are there.
BUT I don't remember the track traces width over the UNO Arduino that whether it can handle 1.5 amps @ 5v of load.
Step 3 will also work and is essentially the same!
Never Step2 because the output of the voltage regulators will be at complete saturation point @ 1.5 amp need.
thanks
I'll go for 3. to avoid burning the arduino track in case they can't handle the current
I'll post the rest of my project in the coming days
