Stand-alone Blue-tooth board
I need sales support for a large volume opportunity.
I need a EDR Bluetooth solution that complies to the following need:
• Work with just power. (Only a connection to a power source)(Disc batteries)
• Stays in discovery mode full-time
• Broadcasts an unique Hardware ID
I need the device to work outside of a computer device. I just need to be able to scan for the hardware ID.
Bill
I don't know what EDR means but I believe you can do that with any bluetooth board that is programmable, which probably means all of them, and all you need do is not attempt to pair with it.
The HC-05 module is an obvious choice, and it will cost you about $3 to find out.
Nick_Pyner:
Enhanced Data Rate
Hmmmm.. Probably not relevant.
