Stand alone version Arduino software
Suddenly all my Arduino's (i.e. Uno R3, ATMega, Nano and MKR1000) stopt working with the stand alone version of the software. Whatever I do I can't get them to work properly. Tried different possible solution posted on the Internet, but no result so far. Finally I tried the web API of Arduino, and all Arduino's seem to work fine. Anybody have an idea what's going on?
I can upload a sketch but Arduino doesn't execute it. Using Windows 10 or Windows Vista makes no difference. Don't get any warnings or anything, just the normal routine.
Tried reinstalling Arduino, other boards, other USB cables, but te result stays the same.
Only the Web API seems to work properly.
Have you verified this occurs with File > Examples > 01.Basics > Blink?
Amongst others, yes
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the upload finishes, copy and paste the full contents of the black console window as the bottom of the IDE window in a reply here USING CODE TAGS (</> button on the toolbar). You will need to scroll up to see the full output.
<Archiving built core (caching) in: C:\Users\jager\AppData\Local\Temp\arduino_cache_644364\core\core_arduino_avr_nano_cpu_atmega328_3985d3028967c06a050ddd1cc11eff1b.a
De schets gebruikt 928 bytes (3%) programma-opslagruimte. Maximum is 30720 bytes.
Globale variabelen gebruiken 9 bytes (0%) van het dynamisch geheugen. Resteren 2039 bytes voor lokale variabelen. Maximum is 2048 bytes.>
<Archiving built core (caching) in: C:\Users\jager\AppData\Local\Temp\arduino_cache_497195\core\core_arduino_avr_nano_cpu_atmega328_3985d3028967c06a050ddd1cc11eff1b.a
Sketch uses 928 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.>
You forgot to use code tags.
That's the output from Sketch > Verify/Compile. You need to do Sketch > Upload.
Sorry,
Archiving built core (caching) in: C:\Users\jager\AppData\Local\Temp\arduino_cache_309971\core\core_arduino_avr_nano_cpu_atmega328_3985d3028967c06a050ddd1cc11eff1b.a
C:\Program Files (x86)\arduino-1.8.5\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\arduino-1.8.5\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b57600 -D -Uflash:w:C:\Users\jager\AppData\Local\Temp\arduino_build_905348/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\arduino-1.8.5\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\jager\AppData\Local\Temp\arduino_build_905348/Blink.ino.hex"
avrdude: writing flash (928 bytes):
Writing | ################################################## | 100% 0.29s
avrdude: 928 bytes of flash written
avrdude: verifying flash memory against C:\Users\jager\AppData\Local\Temp\arduino_build_905348/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\jager\AppData\Local\Temp\arduino_build_905348/Blink.ino.hex:
avrdude: input file C:\Users\jager\AppData\Local\Temp\arduino_build_905348/Blink.ino.hex contains 928 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.22s
avrdude: verifying ...
avrdude: 928 bytes of flash verified
avrdude done. Thank you.
Still forgot the code tags...
Well that's very strange. The upload certainly did complete successfully. I can't think of anything that would cause this problem while leaving the Arduino Web Editor still working.
Can you think of anything that changed between the time the standard IDE was working and non-working?
No, sorry. Everything was working fine till a couple of days ago. Only thing I cabn think of is Windows update.
Thanks for the effort.
