Standalone atmega 328
Hi, I planned to create atmega 328 serial pcb stand alone. Here I can found standalone PCB layout. But, It is for 168 not for 328 P. http://arduino.cc/en/Main/ArduinoBoardSerialSingleSided3
My question is what will happen If I connect 328 instead of 168 controller,
Am I have to change any capacitor and components value to achieve it?
Have a look on atmega48/88/168/328 datasheet and you will found the answer.
In other terms these four micro have the same datasheet and the same pinout. They have difference in memory size ans some internal organization._
Venki: Hi, I planned to create atmega 328 serial pcb stand alone. Here I can found standalone PCB layout. But, It is for 168 not for 328 P. http://arduino.cc/en/Main/ArduinoBoardSerialSingleSided3
It works fine with atmega328 I've tried it with duelmilanove bootloader.
Can use Uno bootloader as well. I load all my 328P projects as Uno, no guessing as what board type to select.
