Standalone AtMega328P - Programming issues
Thanks to all those who responded.
  1. The Vcc is fine at 5.1V
  2. I have removed the 1K resistor from the DTR line
  3. I have checked the RESET pin 1 on the MCU. It goes from 5V to 0V when Reset button is pressed or when DTR is asserted when downloading code ( or trying to download !)
  4. I have changed the crystal
  5. I am yet to change the two 22pf capacitors from pins 9 and 10 to GND.
  6. I loaded the MCU with a simple Blink sketch on a UNO , removed the MCU and put it on this new board. Blink does not blink :frowning:
So its clear that the Oscillator section is dead on board ... but cannot figure out why. For those interested I have attached the schematic as the PCB was made...
I want to use a 30MHz Oscilloscope and see if the oscillator is beating... how to go about this ??
ET-001-R2.pdf (18.7 KB)
