I was just learning the Arduino. I connect Arduino with a standard servo and continuous servo. standard servo rotates from 0 - 180 degrees and then back to 0. continuous servo rotate continuously. why??. I want to be a continuous servo rotates from 0 - 180 degrees and 0.
Standard and continuous servos operate drastically different. A standard servo can be commanded to go to any specific position between 0 and 180 degrees and stop there and hold that position until a new different position command is sent.
A continuous servos is not really a servo anymore due to its modification. A 0 position command will have it turn at some maximum speed in one direction, a 180 position command will have it go some maximum speed in the opposite direction, and a 90 position command will cause it to stop turning. You no longer have the ability to control a continuous servo to move to a specific position and stop. It has been converted such that it's actually a variable speed bi-direction geared motor, nothing more, nothing less, not a servo.
To be able to move to 0 then 180 and then back to 0 either once or continuously requires a standard servo, not a continuous servo.
I suspect many beginners to this hobby purchase 'continous rotation' servos thinking they are getting a 'standard' servo with some extra added feature, when in fact they are getting something entirely different that can no longer function the same as a simple servo. One proper application for a continuous rotation servo is to drive a wheel for motion control on a small car or robot, usually used in pairs.
