can I use a 120 volt 15 amp electric switch for a 30 watt stereo speaker? As is connecting the wires from the stereo and speaker directly to the switch to control speaker individually.
arduinoPi:
Yes, those switch contact specifications will handle 30 watt audio with no problems, assuming you wire up everything correctly.
arduinoPi:
Watts = volts * amps. 120 * 15 = 1800 watts, powerful enough for ~60 speakers at 30 watts.
Perhaps you should take a look at this: --> http://www.thisamericanlife.org/radio-archives/episode/293/a-little-bit-of-knowledge
Don
