Standard AVR programming software
Dear All I have Pololu USB AVR Programmer v2.1 ( Hardware ) I need to upload Arduino boot loader to my Arduino Uno. What I need standard AVR programming software
I need windows software . Not a command line software
I have PROISP 1.72 But it does not support
Please help
Thanks in advanced
Do you have access to a second Arduino board, even for a short period ?
From the Pololu page on the Pololu USB AVR Programmer v2.1.
Works with standard AVR programming software, including Atmel Studio, AVRDUDE, and the Arduino IDE
And here is the user's guide for the programmer.
In the Tools menu, find the Programmer menu, and then select Atmel STK500 development board. If you do not see an entry for the STK500, you should update to Arduino 1.6.5 or later.
Sorry Not available
You are saying you cannot use the IDE Version 1.8.13 or similar in a Win7 or Win10 environment?
I NEED TO READ Fuse bit too
The Programmer will let you do that. It connects to the ICSP header to access the memory areas directly to make fuse changes.
When you select Sketch:Burn Bootloader, it will change the fuses to the values shown in boards.txt.
For the Uno:
uno.bootloader.tool=avrdude
uno.bootloader.low_fuses=0xFF
uno.bootloader.high_fuses=0xDE
uno.bootloader.extended_fuses=0xFD
uno.bootloader.unlock_bits=0x3F
uno.bootloader.lock_bits=0x0F
uno.bootloader.file=optiboot/optiboot_atmega328.hex
I did it but now it does not update by the USB
Did you do Sketch:Upload Using Programmer, or just Burn Bootloader?
Make sure you select the correct Tools:Port for the Uno, you can't leave it as the port for the Programmer.
Skcteh can be uploaded using AVR programmer but it does not by USB port of the Arduino uno, Port also showing with ch340g select Arduino uno and programmer AVRISPkm||
Thanks in advanced
You need to burn the boot loader using your programmer if you want to upload directly via USB.
Yes I did it but it doesn't working via USB
