Start compilataion (Prebuild) Error [Protenta machine control]
Hello I am trying to create a program in IDE PLC for Arduino Protenta machine control in Ladder and i get an error when compile PLC software, the error is given in the "Resources" tab and shows as the following:
--- Start compilation  (PreBuild)  9:42:03 AM ---
--- End   compilation  (PreBuild)  9:42:03 AM ---
--- Start compilation  (PostBuild)  9:42:04 AM ---
Sketch generated, is changed: true
Cannot generate profile file (error message: Error: Path not found)
there is no error on the "Build" tab,
these are the variables and each represent a function block
PROGRAM Main_Ladder
VAR
	Initial_Sequence_01 : Initial_Sequence;
	Locking_Sequence_02 : Locking_Sequence;
	Blower_Mode_03 : DP_Mode;
	DP_Mode_04 : DP_Mode;
	Sensor_Reading_05 : Sensor_Readings;
END_VAR
Does anyone know how to fix this issue?
I found the solution, Arduino PLC IDE needs some tools to be installed before hand, "Arduino-PLC-IDE-Tools_1.0.4_Windows_64bit" with out this tools the PLC IDE wont compile any program.
