Hello everybody,
I’m really a newby in programing with C. I just startet to program and play with an LED bar.
Could you help me to write a program code to start the sequence with an impulse to Digital I/O connector 12 (12VDC)
The program is copied from the templates / samples,now I would integrate some topics.
The function later should be: When I press a button the sequence should be running until I release the button (Digital Input)
Thanks for your help!
regards
zuerchern
Attached is the actual programm, simple but it work!
Starter_Sequenz_1_small.ino (736 Bytes)
Hi, welcome to the Arduino forum.
So if I understand it correctly you want to pulse digital pin 12 (do note it is a 5V digital output and not a 12V output). A good starting point will be the blink led example you can find HERE. This tutorial blinks the onboard LED which is connected to digital pin 13, take a look at this tutorial and see if you can implement code to let digital pin 12 pulse like the way you want.
A tip: If your code isn’t that big just use the code tags (without the double quotes) [“code”]["/code"] to post your code. Then it will look like this:
int timer = 1200;
// use a for loop to initialize each pin as an output:
for (int thisPin = 2; thisPin < 7; thisPin++) {
pinMode(thisPin, OUTPUT);
// loop from the lowest pin to the highest:
// turn the pin on:
digitalWrite(thisPin, HIGH);
delay(timer);
// turn the pin off:
digitalWrite(thisPin, LOW);
// turn the pin on:
delay(timer);
Hi WonderTiger,
Thanks for your fast response. I'm sorry but you have understood me wrong.
I have 6 LED on output (2-7) and I want to start the Loop when I give an input signal to input 12.
When I disconnect the input 12 the Loops should be stopped and all LED should be off.
MY application is later, when I turnover a switch to ON the LED should made a Loop, when I switch back to Off the LED should switches off.
I really tried alot but didn't can't find the correct code.
Thanks a second time for your help!
Regards
Ok, now I see what you want.
So I made a simple example of what you’re trying to achieve, take a good look at it (see the comments) and see if you can figure out yourself how its working and maybe try to implement this to run your own LED sequence. If you got any problems, just post it here. Also take a look at this example provided by arduino.
byte ledPin = 13; // LED is internally connected to this pin
byte buttonPin = 8; // Connect a button to this pin
int ledPulseTime = 2000; // Pulse time for LED
bool buttonState = false;
bool oldPinState = false;
bool currentPinState;
bool validButtonState;
unsigned long timePinStateChanged = 0; // Time used to debounce button
unsigned long timeLedSequence = 0; // Time used for the LED sequence
pinMode(ledPin, OUTPUT); // LED pin as output
pinMode(buttonPin, INPUT); // Button pin as input
validButtonState = readValidButtonState(); // Read debounced button state
if(validButtonState == true) // Rather use if(validButtonState){...}, this is just for demo purposes
runLedSequence(); // Run the LED sequence
digitalWrite(ledPin, LOW); // LED should be off when button isn't pressed...
timeLedSequence = millis(); // Update led sequence time
void runLedSequence()
if(millis() - timeLedSequence < ledPulseTime) // Turn LED on for ... ms
digitalWrite(ledPin, HIGH);
else if(millis() - timeLedSequence < (2 * ledPulseTime)) // Turn LED off for ... ms
timeLedSequence = millis(); // LED has done one blink, update time to the variable that keeps track of the sequence time
ledPulseTime -= 250; // Speed up the LED pulse time
if(ledPulseTime <= 0) // Reset pulse time when it is 0 or below
bool readValidButtonState()
currentPinState = digitalRead(buttonPin); // Read digital pin
if(currentPinState != oldPinState)
oldPinState = currentPinState; // Update old pin state with current read pin state
timePinStateChanged = millis(); // Update variable that keeps track of the time when the pin changed its state
if(millis() - timePinStateChanged > 100) // If pin has same state over 100ms we can safely say that it has debounced
buttonState = currentPinState; // update buttonState
return buttonState; // Return buttonState value
