Hello
could anyone please help me to write the code so that the program starts with a push on the button.
problem is that the stepper motor immediately runs the sketch (when it gets power) and then waits for an push on a button.
Thanks in advance.
sry for my english
CODE:
// defines pins numbers
const int dirPin = 3;
const int stepPin = 4;
const int enPin = 5;
const int switchOne = 8;
const int switchTwo = 9;
int p1buttonState = 0; // current state of the button
int lastp1buttonState = 0; // previous state of the button
int p2buttonState = 0; // current state of the button
int lastp2buttonState = 0; // previous state of the button
bool bPress = false;
bool isForward = false;
bool isBackward = false;
pinMode( switchOne, INPUT_PULLUP);
pinMode( switchTwo, INPUT_PULLUP);
// Sets the two pins as Outputs
pinMode(stepPin,OUTPUT);
pinMode(dirPin,OUTPUT);
pinMode(enPin,OUTPUT);
digitalWrite(enPin,LOW);
isForward = false;
isBackward = false;
p1buttonState = digitalRead(switchOne);
p2buttonState = digitalRead(switchTwo);
if (p1ButtonPress()) {
digitalWrite(dirPin,HIGH);
delay(5);
if (p2ButtonPress()) {
digitalWrite(dirPin,LOW);
delay(5);
if( isForward || isBackward ){
for(int x = 0; x < 800; x++) {
digitalWrite(stepPin,HIGH);
delayMicroseconds(500);
digitalWrite(stepPin,LOW);
bool p1ButtonPress()
bool isPress = false;
// compare the p1buttonState to its previous state
if (p1buttonState != lastp1buttonState) {
// if the state has changed, increment the counter
if (p1buttonState == LOW) {
// if the current state is HIGH then the button went from off to on:
bPress = true;
isPress = true;
Serial.println("Plaer One score");
// if the current state is LOW then the button went from on to off:
Serial.println("off");
isForward = true;
// Delay a little bit to avoid bouncing
delay(50);
// save the current state as the last state, for next time through the loop
lastp1buttonState = p1buttonState;
return isPress;
bool p2ButtonPress()
if (p2buttonState != lastp2buttonState) {
if (p2buttonState == LOW) {
bPress = true;
isPress = true;
Serial.println("Plaer Two score");
isBackward = true;
delay(50);
lastp2buttonState = p2buttonState;
return isPress;
stepper.ino (2.69 KB)
