start reading analog value after key is pressed
Hello everyone,
I have a question about my project using an Arduino Nano, a buzzer, an LDR and a keypad.
My Arduino should start reading the analog value of the LDR after number 4 is pressed on the keypad. When this value comes above a certain threshold the buzzer should activate. The buzzer can be deactivated with a password.
My question is how can I make sure that the Arduino starts reading the LDR value after key 4 is pressed?
  char key = keypad.getKey();
  if (key){
        Serial.println(key);
     if (key == '4'){
      Serial.print("start reading ldr value");
  int ldrvalue = analogRead(ldrpin);
  Serial.println(ldrvalue);
  if(ldrvalue>200)
    Serial.print("buzzer activated          ");
      digitalWrite(buzzpin, HIGH);
   char key2 = kpd.getKey();
   if(key2){
   Serial.println(key2);
    data[sequenceNum] = key2;
    sequenceNum++;
    if (sequenceNum == 4){
      #ifdef DEBUG
      Serial.print(F("Code entered: "));
      Serial.println(data);
      #endif
      if(strcmp(data, "2133") == 0){
        Serial.print("Correct   ");
        Serial.print("Buzzer disabled");
        digitalWrite(buzzpin, LOW);
        delay(100000000);
        Serial.print("Wrong");
      memset(data, 0, sizeof(data));
      sequenceNum = 0;
Thank you in advance.
In the code you posted only the
is dependant on the 4 key. Put the LDR reading code inside the same code block.
First thank you for you help.
Do you mean it like this? because, now I get an error saying that 'ldrvalue' is not declared in the scope.
if (key){
     if (key == '4'){
      if(ldrvalue>200)
Here is your code better formatted
if (key)
  if (key == '4')
if (ldrvalue > 200)
It shows up the problem
ldrvalue is declared local to the if (key =='4') code block, hence the error
It is very weird but i'm still getting the same error, that ldr value is not declared in this scope.
Post your corrected code
#include <Keypad.h>
#define ldrpin A4
#define buzzpin 2
#define DEBUG
const byte ROWS =1;
const byte COLS1 = 1;
const byte COLS2 = 3;
char keys[ROWS][COLS1] = {
  {'4'}
char keys2[ROWS][COLS2] = {
  {'1','2','3'}
byte rowPins[ROWS] = {5};
byte colPins1[COLS1] = {7};
byte colPins2[COLS2] = {8,9,6};
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins1, ROWS, COLS1);
Keypad kpd = Keypad(makeKeymap(keys2), rowPins, colPins2, ROWS, COLS2);
char data[] = "    ";
int sequenceNum = 0;
  #ifdef DEBUG
  #endif
  pinMode(ldrpin,INPUT);
  pinMode(buzzpin,OUTPUT);
if (key)
  if (key == '4')
if (ldrvalue > 200)
   if(key2){
    sequenceNum++;
      #ifdef DEBUG
      #endif
        delay(100000000);
      sequenceNum = 0;
No, that's still got the restricted scope of ldrvalue.
Try making it a global instead.
I'm sorry but I really don't know how to make the ldr value a global value without reading that value the whole time. If I put the analog read statement out of the local scope the buzzer is activated before the key 4 is pressed.
To make ldrvalue global declare it at the start of the program and from then on just use it with no type specifier in front of its name
Maybe i should frame my question different because i'm not really getting what your are saying. f
First my working script looked like this:
  delay(100);
if (ldrvalue > 200)
   if(key2){
    sequenceNum++;
      #ifdef DEBUG
      #endif
        delay(100000000);
      sequenceNum = 0;
But now i want to start this loop only if button 4 is pressed. Can i in some way don't start the loop and only start it when button 4 is being pressed on the keypad?
edit:
I have read about the wait for key function from the arduino keypad library but i don't get that to work maybe you know if I can use that in my case or not.
Now I am confused. What exactly do you want to happen when button 4 is pressed and should it continue after button 4 is released ?
No when button 4 is pressed and released, so just a simple click. The loop should start.
What loop ?
the void loop
it should start reading the analog value of the ldr pin after button 4 is pressed and released.
OK, we are getting closer.
Let me describe what I think you are saying you want
1 - the Arduino is powered up or reset
2 - nothing should happen until button 4 is pressed and released (does it actually need to be released or will just pressing it be OK ?)
3 - the code in loop() runs until the Arduino is powered down/up or reset
Is that correct ?
Yes, that is perfectly what I mean. Button 4 but will in practice be a click so a shot press and release.
An example for you
#include <Keypad.h>
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] =
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte colPins[COLS] = {2, 4, 7, 8}; //column pins  (R0 - R3)
byte rowPins[ROWS] = {10, 11, 12, A0}; //row pins  (L0 - L3)
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
  Serial.println("Press key 4 to start");
  while (keypad.getKey() != '4')
    //do nothing
  Serial.println("in loop()function");
Thank you so much now I got it working.
