I have one issue communicating over serial with a dust sensor.
Here is the datasheet of the dust sensor: Datasheet
The sensor is sending 24 bytes over serial every few seconds.
I started with fetching the data this way:
while (serial_pm.available()<24) {} // Wait 'till there are 24 Bytes waiting
for(int n=0; n<24; n++) {
PMvalues[n] = serial_pm.read(); // Then: Get them.
Serial.print(PMvalues[n]);
Serial.print(" ");
This was working fine before adding other sensors to the setup and using the standby-mode of the dust sensor. Then the output sometimes didn't start with the start character. In example instead of getting:
So I have to change the code that it is working like this: "When receiving the start byte 0x42, then start reading 24 bytes."
My approach was the following, not very elegant, I know:
int start = 0;
int check = 0;
int countread = 0;
int value = 0;
while (serial_pm.available()>0 && check==0) {
value = serial_pm.read();
if (value == 66) {
start = 1;
Serial.println("start");
if (start==1) {
PMvalues[countread] = value;
Serial.print(PMvalues[countread]);
Serial.print(" ");
countread++;
if (countread == 24) {
check = 1;
This didn't work very well. At the beginning I receive full 24 bytes correctly, but after that most of the time the output is something like "-1 -1".
I think I have some misunderstand in how the serial.read is working..
When the start byte arrives, you read AND STORE the data (the next 24 bytes, anyway). Prior to that happening, you just read the data (and discard it).
If you use this idea, the code is pretty simple. Robin2 has a good tutorial on reading serial data, including using start and end markers. The end marker can be a unique value OR can be assumed when some number of bytes has been received.
