start sound module with serial interface of Arduino Micro
I want to start a sound-module (http://www.voicemodul.de/M22P.pdf) with the Arduino Micro over the serial interface (Pin 20 pin 21) . I tried it with the following code, but without success.
#include <SoftwareSerial.h>
#define rxPin 0
#define txPin 1
SoftwareSerial mySerial = SoftwareSerial(rxPin, txPin);
//SoftwareSerial mySerial(0, 1);
// sound-bytes (sound-module M22P) without checksum:
byte sound01 = {0x7E, 0xFF, 0x06, 0x0F, 0x00, 0x01, 0x01, 0xEF};
byte sound02 = {0x7E, 0xFF, 0x06, 0x0F, 0x00, 0x02, 0x01, 0xEF};
byte sound04 = {0x7E, 0xFF, 0x06, 0x0F, 0x00, 0x04, 0x01, 0xEF};
byte sound06 = {0x7E, 0xFF, 0x06, 0x0F, 0x00, 0x06, 0x01, 0xEF};
// initialialize pins:
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
// initialialize serial interface:
mySerial.begin(9600);
mySerial.write(sound01, sizeof(sound01));
delay(10000);
mySerial.write(sound02, sizeof(sound02));
delay(10000);
Where is the mistake?
Using software serial on the hardware serial pins for a start.
What pins are these? Not Arduino pins.
The physical pins of the module...
But these are audio outputs
20 DAC_R Audio output right channel Drive external earphone or amplifier
21 DAC_L Audio output left channel Drive external earphone or amplifier
You need to use the module pins
4 TX UART serial output
5 RX UART serial input
