Start Stop Pause with Button
I’m doing a project with an arduino, a gps module, a microSD module and a bluetooth module.
There is also 2 buttons for the project, one is in charge of sending coordinates to the microSD card and the other one through bluetooth. The first button, the one for microSd card, it has 3 functions: Start, pause, and stop. This is where I need some guidance please!
I’m confused as to how to make a button to pause, and either wait for the start of stop command.
This code is checking buttn1 and 2. If button 1 is pressed, then there will be 3 cases (plus default). This is where I need some suggestions. Please help! How do I make it to where case 2 pauses the loop, and case 3 would I need to add an empty loop too?
thanks
Here is my code so far:
#include <SPI.h>
#include <SD.h>
#include <SoftwareSerial.h>
#include <TinyGPS++.h>
#define button1 7
//#define button2
#define redLED 4
#define greenLED 3
//Pins
const int chipSelect = 10; // setup SD Card Chip Select Pin
int gpsTxPin = A0;
int gpsRxPin = A1;
SoftwareSerial gpsSerial(gpsTxPin, gpsRxPin);
TinyGPSPlus gps;
int state = 0;
int old = 0;
int buttonPoll = 0;
int buttonPoll2 = 0;
pinMode(LED,OUTPUT);
  pinMode(button, INPUT);
  pinMode(redLED, OUTPUT);
  pinMode(greenLED,OUTPUT);
  digitalWrite(redLED, LOW);
  digitalWrite(greenLED, LOW);
  gpsSerial.begin(9600);
  while (!Serial) {
   Serial.print("Initializing SD card...");
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed!");
    digitalWrite(redLED, HIGH);   // turn the LED on (HIGH is the voltage level)
    delay(1000);               // wait for a second
    digitalWrite(redLED, LOW);    // turn the LED off by making the voltage LOW
    return;
  Serial.println("card initialized.");
  CheckButton1();
  CheckButton2();
void CheckButton1()
  buttonPoll = digitalRead(button1); //poll the state of button
  if buttonPoll == 1){
    delay(50);
    buttonPoll = digitalRead(button1); //poll button again
    if(buttonPoll ==0) { //if it's 0 considered one press
    state = old + 1; //incrase stte by 1
  else{
    delay(100);
  switch (state) {
    case 1: //Start
      old = state;
      File dataFile = SD.open("GPSdata.txt", FILE_WRITE);
        // Read GPS Data
      while(gpsSerial.available()>0){
        gps.encode(gpsSerial.read());
      if (gps.location.isUpdated()){
        dataFile.print("Latitude= ");
        dataFile.print(gps.location.lat(), 6);
        dataFile.print(" Longitude= ");
        dataFile.println(gps.location.lng(), 6);
      }dataFile.close();
    case 2: //Pause
      old = state;
    case 3: //Stop
      old = state;
    default;
      old = 0;
void CheckButton2()
  while (digitalRead(button2) == HIGH){
        Serial.print("Latitude= ");
        Serial.print(gps.location.lat(), 6);
        Serial.print(" Longitude= ");
        Serial.println(gps.location.lng(), 6);
    digitalWrite(greenLED, HIGH);   // turn the LED on (HIGH is the voltage level)
    digitalWrite(greenLED, LOW);    // turn the LED off by making the voltage LOW
(deleted)
so basically that just brings the led up right?
I'm not familiar with that line, what does it do?
Haha yes, for the code it might be confusing.
I'm having 2 buttons:
Button#1 will transmit coordinates into a microSD card, and has 3 actions:
Start, Pause and Stop.
The start will start sending the coordinates, as shown on the case1.
Case 2 is for pause, which i'm not sure about that yet, as well as case 3.
Second button this is the one that sends coordinates through bluetooth.
The code for the gps and the bluetooth are good to go, I was just having problems with the case statements and how to set up a PAUSE and STOP button/action/command.
Thank you!
