Start timer when value reaches 0. If value goes above zero in timer, interrupt.
Sorry about the title, I ran out of characters.
I am reading the analog 0 pin. When the pin reads a value of 0, I want it to start a timer. This timer will go on for 5 seconds. If within the timer (when the timer is going) the analog read returns a value greater than 0, I want it to break out of the timer, and call another function.
This is what I have but it doesn’t work because it never stops calling function1() even when the value is above 0.
  if (analogRead(0) == 0 && called == false) {
    if(timer <= 5000){
      timer++;
    else{
      Serial.print("time!");
      called = true;
      timer = 0;
  else{
    function1();
  if(analogRead(0) != 0){
    Serial.println(analogRead(0));
    called = false;
    function2();
The input to the analog pin is an external audio signal.
Thanks,
Dream
  currentTime = millis();
  if (analogRead(0) == 0)
      startTime = millis();
      timing = true;
      timing = false;
  if (timing)
       if (currentTime - startTime >= 5000)
         //do whatever you want
Awesome, it works!
Thanks,
Dream
DreamingInsanity:
Awesome, it works!
Thanks,
Dream
I am glad that I was able to help.
Do you understand how it works ?
UKHeliBob:
I do understand how it works!
Dream
