Hi im kinda new to arduino and i was wondering is there any way to write a program to have my robot start out slow and after few seconds to go full speed? because the whole thing is autonomous i cant use any H bridges or anything else to control the speed myself.
Here is the code that i have for now:
#include <AFMotor.h>
AF_DCMotor motor1(1, MOTOR12_64KHZ); // left create motor #2, 64KHz pwm
AF_DCMotor motor4(4, MOTOR12_64KHZ);// right
Serial.begin(9600); // set up Serial library at 9600 bps
pinMode(16, INPUT); //right
pinMode(15, INPUT); //center
pinMode(14, INPUT); //left
pinMode(2, OUTPUT);//the buzzer
motor1.setSpeed(200); // set the speed of right motor to 200/255
motor4.setSpeed(200); // set the speed of left motor to 200/255
const int pingPin = 19;
int i;
long duration, cm;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
// The same pin is used to read the signal from the PING))): a HIGH
// pulse whose duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
cm = microsecondsToCentimeters(duration);
if (cm <= 80){
motor1.run(BACKWARD);
motor4.run(BACKWARD);
for (i=0; i<255; i++) {
motor1.setSpeed(i);
motor4.setSpeed(i);
delay(10);
}}else{
if (digitalRead(15)==HIGH && digitalRead(14)==HIGH && digitalRead(16)==HIGH){
motor1.run(FORWARD);
motor4.run(RELEASE);
digitalWrite(2,HIGH);
if (digitalRead(15)==LOW && digitalRead(16)==HIGH && digitalRead(14)==HIGH){
motor1.run(FORWARD); // turn it on going forward
motor4.run(FORWARD); // turn it on going forward
if (digitalRead(16)==LOW && digitalRead(15)==HIGH && digitalRead(14)==HIGH){ //if IF signal at the right side is detected rigth motor stops and left motor moves forward
motor1.run(RELEASE);
if (digitalRead(14)==LOW && digitalRead(16)==HIGH && digitalRead(15)==HIGH){ //if IF signal at the left side is detected left motor stops and right motor moves forward
Serial.print(cm);
Serial.print("cm");
delay(100);
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
