started && ended question
hii every budy /// im trying to send 2 float numbers via xbee using packet marker () {} ... my problem that i cant find the original arduino code for this method i found several codes for proccessing and bytes but couldent make it work ... so if any one can direct me into asimple arduino code it would be great cus i realy searched alot /// thanks in advance ///
boolean started = false;
boolean ended = false;
char inData[24]; // Size as appropriate
byte index = 0;
#define SOP "{"
#define EOP "}"
   while(Serial.available() > 0)
      char inChar = Serial.read();
      if(inChar == SOP)
         started = true;
         index = 0;
         inData[index] = '\0';
      else if(inChar == EOP)
         ended = true;
         if(index < 24-1) // Array size
            inData[index++] = inChar;
   if(started && ended)
      // Parse the data in inData here...
thanks alot paul i will try this code cus mine is very very long here :
char charIn = 0;
byte i = 0;
char stringIn[32] = "";
char startchar;
float availableData = Serial.available();
if ( availableData > 0 ) {
startchar = Serial.read();
if ( startchar == '{' ) {
while ( charIn != '}' ) {
if ( Serial.available() > 0 ) {
charIn = Serial.read();
if ( charIn == '}' ) {
stringIn = charIn;
  • i += 1;*
  • float lat1= atof(stringIn);*
  • Serial.println(lat1,7);*
  • delay(3000);*
if ( startchar == '(' ) {
  • while ( charIn != ')' ) {*
  • if ( Serial.available() > 0 ) {*
  • charIn = Serial.read();*
  • if ( charIn == ')' ) {*
  • break;*
    _ stringIn = charIn;_
    * i += 1;*
    * float lon= atof(stringIn);*
    * Serial.println(lon,7);*
    * delay(3000);*
Serial.available() can hardly report that there are 3 and half characters to read, now, can it?
  char charIn = 0;
  byte i = 0;
With these as local variables, an entire packet would need to be available to be read in a single iteration of loop. That seems highly unlikely.
