Starter experiment/ invalid library
Hello, I'm new in programming with Arduino.
I'm trying with an exemple of the sketches Blink. I have download my own sketch of the Blink program, I have checked that my board type and serial port are set correctly, they are. And when I try to upload it , it says that my library is unvalid. I'm not sure I understand why ? Can somebody help me?
Thanks in advance
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Please post your full sketch here using code tags as described in How to get the best out of this forum
Here is my sketch, sorry for the mistakes that I made with the forum, I'll try my best to respect all the policy! I'm using the Arduino Uno
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
  // initialize the digital pin as an output.
  // Pin 13 has an LED connected on most Arduino boards:
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);   // set the LED on
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // set the LED off
Pleas post the full error message by clicking on the "Copy error messages" button in the IDE and posting them here in code tags
Which Arduino board are you using ?
I'm using the Ardino uno board,
It's all good I solved it. The problem was coming from ,where I downloaded my sketch and the communication with my USB driver and the arduino uno.
Thanks and sorry for the bother
I am glad you solved it
With such a simple sketch an error message about a library was very unlikely
