If i buy the advanced arduino starter kit found at Maker Shed: Official Store of Make: and Maker Faire since 2005, what projects could i make out of the box? and if i bought it would it be compatible with the kit found here Maker Shed: Official Store of Make: and Maker Faire since 2005, will it be compatible right out of the box with the other kit, or will i need some adapters?
You could make a hell of a lot of stuff...
Features
1x Arduino Duemilanove (ATmega328)
1x Mini breadboard Always useful
1x Adafruit Protoshield (assembly required) Can be used for everything
1x 6FT. USB Cable
1x Making Things Talk book
1x 9V Battery Case w/DC Plug (assembly required)
1x 9V Battery
Make Arduino Pack:
10x 330 resistors
10x 10K resistors
10x 1K resistors
10x 10nF ceramic capacitor
10x 100nF ceramic capacitor
5x 100uF electrolytic capacitor
1x 40pin male breakaway headers
1x Half size basic breadboard
1x 75pcs deluxe jumper wire pack Good
5x Mini Push Button for breadboard Inputs
3x DPDT switch for breadboard
2x Thermister Temperature projects
5x Basic Green LED Indicator
5x Basic Red LED Indicator
3x 5mm RGB LED Mood lights/indicators
1x Piezo Buzzer Knock sensors/audio output
1x 6 pin stackable female header
3x 8 pin stackable female header
5x 8 pin female header
1x 40pin male breakaway dual-headers
1x Harness for Arduino/Seeeduino kit
2x Proto board Good for building up circuits on
1x Heat shrink tubing
2x Tilt Sensor Hmm, alarmed devices etc
1x Rotary Potentiometer Analog input/calibration/control
1x Mini DC motor Basic movement
1x Vibration Motor Vibration indicators
1x Transistor NPN For powering motors
1x Diode
2x Photoresistor Light sensitive projects
1x Component box Box for everything
I hope a few of those comments help you. There are so many different projects you could do. I presume you have a box of broken electronics that you can steal parts off as well!
Mowcius
Right, you could do many projects, but only if you know how to combine the above-mentioned parts.
As a total beginner with no experience whatsoever, I would rather go for specialized kits, like ladyada's WaveShield, or GPS logger (in addition to an Arduino, of course), or something that can give immediate results and satisfaction.
Well you can do a hell of a lot of simple projects with that kit. The other thing is that it provides you with a supply of simple components for all projects. IF you don't have any simple components (LEDs, Resistors etc) then you will need some.
Mowcius
Yes but as a beginner with no experience, I know from experience that unless you just want to do exactly what is done on any sample code, they are not easy to code for. As a beginner, simple commands are not so simple...
Mowcius
That looks good, but makershed overprices many things and their shipping is very high. By the arduino starter kit at adafruit.com. It is only 60 dollars and you can also buy other parts you need from her broad selection. Shipping is sheap too. I wouldn't recommend getting a specialty kit yet, but adafruit is a lot better than makershed and you get a lot more bang for your buck.
And to answer your question, yes you could do TONS of projects with either of those kits.
