starting a loop under condition
Hello Arduino users
I would like to start a servo motor when my distance sensor read the right distance ...
I can setup the sensor
I can have the servo motor working
but how can I start the servo to rotate when (for example) an object is close to the sensor ?
is it a matter or "if ... then" ? Kind regards Philippe
is it a matter or “if … then” ?
if(distance <= threshold)
   // Make the motor move
That would be as simple ?
here’s the code to set the sensor :
// trigger > digital7 : echo > digital6 : plus > +5V : moins > GND
//led : plus > digital13 : moins > digitalgnd
#define trigPin 7
#define echoPin 6
#define led 13
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(led, OUTPUT);
long duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance <= 12) {
  digitalWrite(led, HIGH);
else {
  digitalWrite(led,LOW);
here’s the servo code
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0;    // variable to store the servo position
myservo.attach(9);  // attaches the servo on pin 9 to the servo object
for (pos = 0; pos <= 90; pos += 1) { // goes from 0 degrees to 180 degrees
  // in steps of 1 degree
  myservo.write(pos);              // tell servo to go to position in variable 'pos'
  delay(50);                       // waits 15ms for the servo to reach the position
delay(5000);
for (pos = 90; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
while(1){}
then how to mix them please
Kind regards
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. Using code tags and other important information is explained in the How to use this forum post. Please read it.
pert:
done :wink:
That depends on whether you want to make split pea soup or ice cream from the two ingredients.
PaulS:
Thanks a lot for your precious help …
I followed your advice by the way …
// Turning NeoPixels on and off using a HC-SRO4 Ping Sensor
   This sketch reads a HC-SR04 ultrasonic rangefinder and returns the
   distance to the closest object in range. To do this, it sends a pulse
   to the sensor to initiate a reading, then listens for a pulse
   to return.  The length of the returning pulse is proportional to
   the distance of the object from the sensor.
   The Arduino then takes this information and initiates a series of
   sweeps. A sweep is defined as the servo moving its horn from the
   0 position to 180 and back to 0 then to -180 and back to 0.
   This code was developed partially from Ping))) code found in the public domain
   written by David A. Mellis, and adapted to the HC-SRO4 by Tautvidas Sipavicius,
   while other portions were written by Charles Gantt and Curtis Gauger from
   http://www.themakersworkbench.com.
   This code was written for a tutorial on http://www.themakersworkbench.com,
   and was designed for use in a project built by The Young Makers of Greater Augusta.
//Tell the Arduino Ide to include the Servo.h library.
#include <Servo.h>
 //Setup the variables for the HC-SR04
 const int trigPin = 6;
 const int echoPin = 7;
 // a maximum of eight servo objects can be created
Servo myservo;
int pos = 0;
  // initialize serial communication:
  myservo.attach(9);
  // establish variables for duration of the ping,
  // and the distance result in inches and centimeters:
  long duration, inches, cm;
  // The sensor is triggered by a HIGH pulse of 10 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  // Read the signal from the sensor: a HIGH pulse whose
  // duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  // convert the time into a distance
  inches = microsecondsToInches(duration);
  cm = microsecondsToCentimeters(duration);
  //Tell the Arduino to print the measurement in the serial console
  Serial.print(inches);
  Serial.print("in, ");
  Serial.print(cm);
  Serial.print("cm");
  // This if-else statement tells the Arduino at what distance
  // it should trigger the servo, what the servo should do,
  // and what it should do if the distance is too far away.
   if (inches <= 3)  {sweep(1);
   else if (inches >= 3) {myservo.write(pos);
   // Tell the Arduino to wait 0.10 seconds before pinging the
   // Ultrasonic Sensor again.
   delay(100);
// Converts the microseconds reading to Inches
long microsecondsToInches(long microseconds)
  // According to Parallax's datasheet for the PING))), there are
  // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
  // second).  This gives the distance travelled by the ping, outbound
  // and return, so we divide by 2 to get the distance of the obstacle.
  // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
  return microseconds / 74 / 2;
//Converts the Microseconds Reading to Centimeters
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
//This sub-routein is what dictates the movement of the servo
void sweep(int NUM_OF_CYCLES)
// Tells the Arduino to start this loop at 0 and incriment it by 1
// each time the loop completes. This is how the Arduino knows to
// stop the loop when a specific number of the Sweep routein has been ran.
  for(pos = 0; pos < 90; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
  delay(5000);
  for(pos = 90; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
that works
philippef: but how can I start the servo to rotate when (for example) an object is close to the sensor ?
Yo want to start the servo when an object is close to the sensor? But, an object will be close to the sensor for a period of time. You you want to keep starting it ivery few microseconds? Or do you want to start the servo when an object is close to the sensor and it was not previously close to the sensor? Or something like:
if * an object is close to the sensor * and it has been close to the sensor for .1 seconds * and the servo is currently stopped and has been stopped for 2 seconds
You really have to break it down to exactly what sequence of events you want.
