Hi friends,
I have two arduino boards (one arduino Uno and another one is a 100% compatible clone which has some switch and light peripherals.) And recently, I bought two Xbee series two radios (digi branded). Now, I dont have any xbee explorer or xbee breakout boards, I am just connecting relimate connectors to take the four pins from the xbees.
This is my setup:
One xbee connected to arduino Uno (2nd pin for tx and 4th pin for rx using the SoftwareSerial library) - the four pins of xbee are connected as power to 3v3 of arduino, GND to GND of arduino and tx and rx to respective pins (2nd and 4th pin).
Another xbee is connected to the clone (here I used the default tx and rx pins - 0 and 1).
Now, what I need to start a talk between the two boards wirelessly?
I tried many example programs over the Internet. But nothing is of use.
All I want to do is that, When I press a button on the clone, some character must be transmitted and displayed on the serial monitor (The arduino Uno is connected to the computer with the default tx and rx pins (this is the reason i used duplicate tx and rx for the radio on the UNO). I have been trying this for 4 days....
First, add some resistor dividers so the 5V output TX pin from the Arduino does not damage the 3.3V Rx input pin on the Xbee.
"Series two" - how much power do they need? I think the 3.3v regulator on the arduino is only good for 150mA, and "series two" might need more than that.
I searched the www.digi.com website and did not see Series two there, so not quite sure what you're referring to.
How did you configure them? Digi claims that no configuration is required. That’s bulls**t.
Serial.print() on the one connected to the hardware serial port, and mySerial.print() (or whatever instance name you use for the software serial instance) on the other to send, and the corresponding available() and read() methods to read the data.
@PaulS and CrossRoads: Thanks for your valuable replies. :)
@CrossRoads : I am referring to this module to be in particular - xb24-z7wit-004
@PaulS: I didnt configure them coz, i just bought only the bare modules (I mean no breakouts or pc to xbee interfacing boards)
and tried that Serial.print and myserial.print etc commands.. but of no use.
Could anyone of you post the sample code to test the communication and the wiring setup b/w the arduinos and xbees? That would be of great help and starting for me!
Hi PaulS,
Do I need a xbee explorer to configure the xbees or we can still configure it by codding to the arduino?
and CrossRoads,
I didnt buy the pro type... bought the ordinary one.. these are the things written on the xbee:
digi international
Xbee
S2
Its the first one which states, the transmit and receive currents are 35/45mA and 38/40mA respectively.
Is there any coding to initialize the xbee using only the microcontroller? coz, I dont have a serial to usb adapter to make xbee directly talk to my laptop computer via X-CTU.
