Starting serial monitor causes servo jitters
Why would starting up the serial monitor function cause servo's hooked up the arduino to jitter?
Are there any pitfalls to watch out for with servo control, where you get strange results of unexplained servo movement from either peripheral devices or code?
might be cause by the interrupts used by the serial communication?
if you send characters does it happen more?
Northof49:
When you open up the serial monitor it causes the attached arduino to perform a auto-reset, start of the bootloader code, and finally a jump to your sketch. This is most likely the reason you are getting a servo jitter. To test this, instead of opening the serial monitor just press the reset button on the arduino and see if the servo reacts the same.
Yes, the reset does produce servo movement. Thanks for pointing out that the serial monitor causes a reset.
