Starting Serial monitor resets PWM outputs
As in the title, I am using two timers Timer1 and Timer2 pwm outputs. I setup the timers and serial comms and the main loop is just transmitting some test characters. All serial comms are established using arduino functions. On scope, I see that when I start Serial Monitor on my computer, the pwm outputs momentarily reset to zero. Is this a known bug? Is there some way to avoid this?
Code follows:
void setup(){
  GTCCR = (1<<TSM)|(1<<PSRASY)|(1<<PSRSYNC); // Halt all Timers
   // TIMER1 settings --------------------------------------------------
   TCCR1A = 0; // Reset TIMER 1 Control Register A
   TCCR1B = 0; // Reset TIMER 1 Control Register B
   TCCR1A |= (1 << COM1A1) | //
             (0 << COM1A0) | // Clear OC1A on Compare match up counting
             (1 << COM1B1) | //
             (1 << COM1B0) | // Set OC1B on Compare match up counting
             (0 << WGM10)  |
             (0 << WGM11)  ;
   TCCR1B |= (0 << WGM12)  |
             (1 << WGM13)  | // PWM Phase Freq correct, TOP=ICR1, fund freq 60Hz, switching freq 15.63kHz
             (1 << CS10)   ; // No Prescalar
   ICR1 = 0x0209; //  TOP=523, Switching Freq = 15.6kHz, sinetable256
  // TIMER1 default dutycycle
     OCR1A = 0x00;
     OCR1B = 0x00;
  // TIMER1 interrupt settings
  TIMSK1 = 0; // Reset Timer1 interrupt mask register
  TIMSK1 |= (1 << TOIE1) ;  // Timers1 Overflow interrupt TOV1 bit set when TCN1=BOTTOM
  TIFR1 = 0; // Reset Timer1 interrupt flag register
  // TIMER2 settings -------------------------------------------------------
  TCCR2A = 0; // Reset TIMER 2 Control Register A
  TCCR2B = 0; // Reset TIMER 2 Control Register B
  TCCR2A |= (1 << COM2A1) | //
            (0 << COM2A0) | // Clear OC2A on Compare match up counting
            (1 << COM2B1) | //
            (1 << COM2B0) | // Set OC2B on Compare match up counting
            (1 << WGM20)  |
            (1 << WGM21)  ; // Fast PWM, TOP=0xFF, 62.74kHz
  TCCR2B |= (0 << WGM22)  |//
            (1 << CS20)   ; // No Prescalar
   // TIMER2 default dutycycle
    OCR2A = 0x00;
    OCR2B = 0xFF;
  // TIMER2 interrupt settings
   TIMSK2 = 0; // Reset Timer2 Interrupt mask register
//   TIMSK2 |= (1 << TOIE2) ;  // TIMER2 Overflow interrupt TOV2 bit set when TCN2=BOTTOM
  // TIMER2 asynchronus status register
  ASSR = 0; // Reset Async status register, TIMER2 clk = CPU clk
      // set all timers to the same value
  TCNT1 = 0x0000; // set timer1 to 0
  TCNT2 = 0x00; // set timer2 to 0
  GTCCR = 0;  // release all timers
  // Serial communication settings---------------------------------------
void loop(){
  // prints value unaltered, i.e. the raw binary version of the
  // byte. The serial monitor interprets all bytes as
  // ASCII, so 33, the first number,  will show up as '!'
  Serial.write(thisByte);
  Serial.print(", dec: ");
  // prints value as string as an ASCII-encoded decimal (base 10).
  // Decimal is the  default format for Serial.print() and Serial.println(),
  // so no modifier is needed:
  Serial.print(thisByte);
  // But you can declare the modifier for decimal if you want to.
  //this also works if you uncomment it:
  // Serial.print(thisByte, DEC);
  Serial.print(", hex: ");
  // prints value as string in hexadecimal (base 16):
  Serial.print(thisByte, HEX);
  Serial.print(", oct: ");
  // prints value as string in octal (base 8);
  Serial.print(thisByte, OCT);
  Serial.print(", bin: ");
  // prints value as string in binary (base 2)
  // also prints ending line break:
  Serial.println(thisByte, BIN);
  // if printed last visible character '~' or 126, stop:
  if(thisByte == 126) {     // you could also use if (thisByte == '~') {
    // This loop loops forever and does nothing
    while(true) {
      continue;
  // go on to the next character
  thisByte++;
This is normal. It resets the Arduino. No way around it
There are a few tricks for disabling the auto-reset feature. Google should find them. If you disable it permanently you will find it difficult to upload new programs.
If you have a USB-TTL adapter you could connect it to the Rx, Tx and GND pins only and use that to communicate with the Arduino rather than the regular USB connector. But that arrangement won't supply power to the Arduino.
...R
