Starting the loop after Serial.read
Hey guys, I'm just wondering if there is any way I could replace:
command = Serial.read();
switch(command){
case '1':
pin1();
pin2();
case '0':
brightness = 0;
brightness2 = 0;
fade = 3;
fade2 = 10;
delay(30);
With something that will ask for input and then on switch statement (Or any other way) start the loop. So that I don't have to use a loop in C# to write to this one every 30 MS... Thanks!
Do not do this
until you've done this
if (Serial.available()>0){
// your stuff
Then loop() can be doing other stuff until a byte comes in.
Falcuun:
switch(command){
case '1':
pin1();
pin2();
case '0':
brightness = 0;
brightness2 = 0;
fade = 3;
fade2 = 10;
delay(30);
What?
If you want your task to be repetitive you must loop. Otherwise you don't have to loop. What is your project?
Falcuun:
It makes no sense to start loop() after loop() is started. To delay starting loop() until an input arrives, wait for the input in the function that happens before loop(): setup()
  int command;
  do
  while (command != '0' && command != '1');
  switch (command)
    case '1':
      pin1();
      pin2();
    case '0':
      brightness = 0;
      brightness2 = 0;
      fade = 3;
      fade2 = 10;
  delay(30);
This is C++, not C#
DH12043:
This is C++, not C#
That is a cryptic comment
...R
Robin2:
That is a cryptic gnomic comment
AWOL:
Sorry, but that is even more cryptic - at least for my limited experience.
...R
