starting up Arduino
Just purchased the starter program. I've followed all the instructions, but can't get past the 'blink' program. All efforts to change the program so the blink rate changes, have failed. I'm using a Mac, and everything seems to be okay, but changing the blink rate will not work. Message says 'uploading', then 'done uploading', but obviously my program changes are not taking effect. I don't know what else to try. Would appreciate your help!
Greg Harter
blairgbh:
Greg Harter
There is absolutely nothing anyone can do to help if you don't post your code. Please post it within [code]code tags[/code] too, not inline.
If the IDE compiles your code, then shows "Uploading" ... "Done Uploading", it should be working fine.
Select File:Prefences and select Verbose outputs.
Then grab the stuff that shows up in the bottom and paste it here using the code tags button </>
Which Arduino IDE version are you using?
Which Arduino board are you using?
Please post your modified blink program using code tags(</> button on the toolbar).
Here’s the program; all I did was change the milliseconds from 1000 to 100.
Under file, there is no preferences choice at the Arduino website.
// the loop function runs over and over again forever
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(100); // wait for a second
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
Thanks in advance for your help!
BTW, I don’t know how to use the </>, so I just copied the program so all could see.
You click it, then paste your code in the box that appears:
your code here
Please answer pert's questions in reply #3
blairgbh:
No, you should look in the IDE under file -> preferences :wink:
I'm using an Arduino Genuino Uno, purchased from Arduino and received three days ago. My Mac is using 10.11.1, El Capitan, which is a very current version. I don't know why the board and the computer aren't communicating.
I appreciate everybody's offer to help, you need to be more specific with a guy (me) who doesn't understand programming/language very well.
Thanks!
Also, here's the info requested earlier:
BN: Arduino/Genuino Uno
VID: 2341
PID: 0043
SN: 9543731343435110E031
blairgbh
And the software is version 1.6.10.
You need to show all of the code, including ‘setup()’, rather than just the ‘loop()’ function.
Also, please do what CrossRoads suggested - in the IDE’s “>File >Preferences”, check the boxes to enable verbose output during compiling and uploading. Then, if there are any errors, (they’ll be in orange text), select the error text, press Ctrl-C to copy, then paste the errors into a post.
When you post your code and/or the error messages, first paste each into a reply, then select it ans press the </> button, which will wrap the code/error message in code tags.
Otherwise, you can type code tags manually. Type
[code]
immediately before the code that you pasted, then
[/code]
immediately after it. Include the square brackets.
From what you’ve shown of the code, the LED should be blinking rapidly - on for 0.1 seconds, off for 0.1 seconds, repeating.
Are you still seeing “Uploading”, then “Done uploading” during the upload process?
There have been some problems with uploading using IDE V1.6.10 when a sketch is opened by clicking directly on the *.ino file. You could try closing the IDE, re-opening it then loading the sketch by clicking on it in “>File >Open Recent”, then uploading it.
IDE V1.6.9 is much more stable, with less problems than V1.6.10.
Just tried it again. Still seeing 'uploading' and 'done uploading', but the blinking cursor remains at 1 sec on, 1 sec off, etc.
I enabled verbose output, and the only lines that showed up orange were the last three:
Using Port : /dev/cu.usbmodem1A21
Using Programmer : arduino
Overriding Baud Rate : 115200
The USB port seems to be working okay, I downloaded a .ppt file to a thumb drive last week, and then uploaded the same file through the same port with the thumb drive.
and here is all of the code:
// the setup function runs once when you press reset or power the board
  // initialize digital pin 13 as an output.
  pinMode(13, OUTPUT);
I'm not knowledgeable enough to know what adding the code in brackets before and after, means.
If this does not reveal a problem, should I try to install 1.6.9? How would I do that?
Sorry this is such a problem. Thanks for your patience and help.
There's absolutely nothing wrong with the code. I thought that maybe you didn't have the 'pinMode()' statement in 'setup()', but it's fine. (My UNO's on-board LED is happily blinking at the rate shown in your code.)
I forgot that the whole upload process would show in orange, not just errors, but it still shows that something is wrong there. Despite the fact that the IDE says "Done uploading", it's clear that the process didn't complete.
The upload message should be much longer, more like this:-
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM4
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: reading input file "C:\Users\Steve\AppData\Local\Temp\buildb2290698c276240de51abeb4cd7c02b9.tmp/sketch_aug06d.ino.hex"
avrdude: writing flash (1066 bytes):
Writing | ################################################## | 100% 0.18s
avrdude: 1066 bytes of flash written
avrdude: verifying flash memory against C:\Users\Steve\AppData\Local\Temp\buildb2290698c276240de51abeb4cd7c02b9.tmp/sketch_aug06d.ino.hex:
avrdude: load data flash data from input file C:\Users\Steve\AppData\Local\Temp\buildb2290698c276240de51abeb4cd7c02b9.tmp/sketch_aug06d.ino.hex:
avrdude: input file C:\Users\Steve\AppData\Local\Temp\buildb2290698c276240de51abeb4cd7c02b9.tmp/sketch_aug06d.ino.hex contains 1066 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.15s
avrdude: verifying ...
avrdude: 1066 bytes of flash verified
avrdude done.  Thank you.
Did you try my suggestion of "closing the IDE, re-opening it then loading the sketch by clicking on it in ">File >Open Recent", then uploading it."?
Anyway, personally, I'd get rid of V1.6.10 and use V1.6.9, since it's proven to be more reliable than V1.6.10.
I can't help much with the process of uninstalling/installing on a Mac, sorry. I'm a Windows user. (But I guess it's just a matter of deleting the installation folder?)
You can get IDE V1.6.9 here:- Previous IDE Releases
And there's basic installation info here:- Getting Started w/ Arduino on Mac OS X
Good luck. :slight_smile:
First I tried closing the IDE, reopening and reloading the sketch. Didn't work.
Then I put 1.6.10 in the trash, and loaded 1.6.9, opened, uploaded the sketch, then changed the values to 100 milliseconds, and reloaded. Still didn't work.
I did notice that the serial port shows a slightly different message than what's in the Arduino manual. Manual says it should say /dev/tty.usbmodem, but on my Mac it says /dev/cu.usbmodem. Also, there is only one choice, not two.
Finally, I don't see the rx and tx LEDs lighting up when I upload.
If there's nothing else to try, I'll be glad to talk with the Arduino folks........but there's no phone #, and they haven't responded to my request for help yesterday.
Any other suggestions? Again, thanks for your patience, I really don't know what's wrong here.
I did notice one other thing. I haven't changed anything on the Arduino board, but is it possible somebody put the IC on upside down? I can't tell from the pictures in the manual where the notch should be. It's at the bottom of the board when the USB port is at the top. Is that correct? I would think these things are tested before they are verified and shipped, but one never knows.
Thanks.
What where who ?
Can you post a picture of the board ?
Maybe add some other info like the IDE, OS etc ?
You could also look up the Atmel pin-out and verify the ground and VCC to ensure you know its in correctly.
Doubtful it was inserted wrong but stranger things have happened.
Best bet is remove all external wiring first and throw the blink sketch at it.
If that works then you at least know where the problem probably is.
blairgbh:
That works in some cases. A lot of people have had a problem uploading when the sketch is opened by clicking directly on the *.ino file.
Neither do I at this stage.
As I mentioned, I don't use a Mac, (never have), so I can't help with anything Mac-specific.
No, I didn't think you would. The uploading output that you posted indicates that the upload process doesn't get started at all.
I don't know what else to try. Pity you don't have a second board to test. That would eliminate problems with the board itself.
Thanks.
The IC is correctly oriented. The notch, and therefore pin 1, should be at the opposite end ofthe board to the USB socket.
At this stage, I'm as lost as you. You'll have to hope that someone else comes along with another suggestion.
Ballscrewbob:
What where who ?
That’s all been previously mentioned.
Originally the problem appeared with IDE V1.6.10. He’s now uninstalled that and installed V1.6.9, but the same problem persists.
The board is an original UNO, and the chip is oriented correctly. (Same as my UNOs.)
That’s exactly what’s not working. The sketch is a modified “Blink”, with 100mS ‘on’ and ‘off’ periods, (posted on the previous page, and tested by me. Nothing wrong with the code.), but it won’t upload, and the upload output message is shown on the previous page of this thread. It doesn’t get beyond “Overriding Baud Rate : 115200”, but shows “Done uploading”.
As I say, all of this has been previously mentioned.
Sorry for coming in late.
Failed to notice it was page 2...my own fault.
Only saw the first post from P2...will try take more care.
Odd how so many macs are having so many issues right now.
Anyone know what was the most stable IDE for the mac's
