Startup function in Bitlash won´t execute if created during compile time.
Hi!
I´m not sure if this is the right place for Bitlash questions but here goes.
I want to create a Bitlash function that is called when Bitlash is booted up. This can be done during runtime using: function startup {print "Some nice text\n",;};
My question is how to add this function or behavior in my sketch? I have tried to create a user function like below but it doesn't seem to be called during boot.
numvar startup(void) {
        Serial.write ("Some nice text\n");
addBitlashFunction("startup", (bitlash_function) startup);
the function call needs to be inside a function, not at global scope.
To call a function before setup() runs, use a global variable.
struct SetupBitlash{
  SetupBitlash(){ addBitlashFunction("startup", (bitlash_function) startup); }
SetupBitlash sbl;
Thanks for the prompt answer! :open_mouth:
I didn't get what you suggested to work. It compiles fine but the startup function is still not being called during boot. I managed to get it to work in another way though.
I added a user built-ins function in ..src\bitlash-builtins.c
BUILT_IN("startup",     "print \"Some nice text\"")
I have no idea if this is the correct way of doing it though...
