startup with analogwrite function
i am new in the forum and i have not found an answere on my question right now.
i want to use the analogwrite function to dim a led.
everything is fine, but the pin output starts with the high value and not with the lowest value.
code:
void setup (
Pinmode (3, Output)
void loop (
Analogwrite (3,100)
Before the led has a lower brightness, it starts with the maximum brightness.
how can i set the pin, that the led starts with the lowest brightness before getting the dimmed value?
thank you for your help.
have a nice time.
kind regards
rumble
Rumble2006:
void setup (
  analogWrite(3, 0);  // Start at 0 brightness
// Note: The first line in analogWrite(pin,brightness) is "pinMode(pin, OUTPUT);"
void loop (
  analogWrite (3,100);
Hi johnwasser,
thank you very much.
Sometimes it fails on the simple things.
Bye.
