State change for 28BYJ-48 stepper direction control - help needed
Hi all forum members,
Beginner needing some help here, been struggling with this for quite a while now. Basically, I’m trying to setup a couple of State Change rules to control the direction of a motor. However, I think with either my wiring or code (or both) I cant make any inroads into this past even getting the arduino to recognise that the state change should have occurred. So any help at all from some seasoned experts would be greatly appreciated.
I’m using a 5 wire 28BYJ-48 stepper motor, and want to be able (at least at the very start) to just get it to change direction based on the button being pressed twice.
Not sure how much information is not enough or too much but...
I've attached a picture to display the circuit and below is the code:
// this constant won't change:
const int  buttonPin = 12;    // the pin that the pushbutton is attached to
int Pin0 = 3;
int Pin1 = 8;
int Pin2 = 2;
int Pin3 = 5;
int _step = 0;
boolean dir = true;// gre
// Variables will change:
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
#include <Stepper.h>
// steps value is 360 / degree angle of motor
#define STEPS 64
// create a stepper on pins 2, 3, 8 and 5
Stepper stepper(STEPS, 2, 3, 8, 5);
  // initialize the button pin as a input:
  pinMode(buttonPin, INPUT);
  // initialize the LED as an output:
 pinMode(Pin0, OUTPUT);
 pinMode(Pin1, OUTPUT);
 pinMode(Pin2, OUTPUT);
 pinMode(Pin3, OUTPUT);
  // initialize serial communication:
  // read the pushbutton input pin:
  buttonState = digitalRead(buttonPin);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      // if the current state is HIGH then the button
      // went from off to on:
      buttonPushCounter++;
      Serial.println("on");
      Serial.print("number of button pushes:  ");
      Serial.println(buttonPushCounter);
    else {
      // if the current state is LOW then the button
      // went from on to off:
      Serial.println("off");
  // save the current state as the last state,
  //for next time through the loop
  lastButtonState = buttonState;
  // initiates motor clockwise else the motor runs counterclockwise
  // checking the modulo of the button push counter.
  // the modulo function gives you the remainder of
  // the division of two numbers:
  if (buttonPushCounter % 2 == 0)
     switch(_step){
   case 0:
     digitalWrite(Pin0, LOW);
     digitalWrite(Pin1, LOW);
     digitalWrite(Pin2, LOW);
     digitalWrite(Pin3, HIGH);
   case 1:
     digitalWrite(Pin2, HIGH);
   case 2:
     digitalWrite(Pin3, LOW);
   case 3:
     digitalWrite(Pin1, HIGH);
   case 4:
   case 5:
     digitalWrite(Pin0, HIGH);
     case 6:
   case 7:
   default:
    stepper.setSpeed(232);
    stepper.step(2048);
    delay(3000);
    switch(_step){
   case 0:
   case 1:
   case 2:
   case 3:
   case 4:
   case 5:
     case 6:
   case 7:
   default:
    stepper.step(-2048);
    delay(3000);
Why are you using a Stepper instance and stepper.step commands and at the same time manipulating the stepper pins directly?
Not sure if i am overcomplicating it, but in general I need a way to get feedback to the motor connected pins to work in opposite directions. At the moment I'm not getting any response that indicates that the button change has been detected at all - so thats the first main issue. Instead the switch just temporarily stops the motor running each time it is pressed.
I'd get rid of all the stuff that touches the stepper pins and just use the stepper.step code. Preferably just stepping one way and just after this:
Then you can see if your button press and stepper are actually working. If they are, add a boolean flag that tells you whether to do a positive or negative number of steps.
