State change using keypad
I want to control servo using keypad if i press # i want the servo to go 180degree and if i press # i want the servo to fo to 0 degree .
Im confused if key.getkey(); return the char once if the key is in hold or it return the char continously if the key is holded
What library is getkey() from?
marwan12:
It returns it only once assuming you are using the Keypad library.
ToddL1962:
Thanks
ToddL1962:
There is only one Keypad library? I ask because it's not officially listed in Reference.
aarg:
author Alexander Brevig
im using keypad library by Alexander Brevig
