Hi all,
I am building an aquarium controller to monitor temperatures and perform automatic water changes for me. I have all the hardware in place and working and am just working on programming my arduino.
I have it to a stage where it will display temps from two DS18B20 temperature probes on the LCD, it will also react to two float switches and a button to turn relays on/off to perform the water change.
Ultimately what I would like it to do is:
-Monitor 2 x temps, one in the actual aquarium and one in the header tank I have to provide water for top ups. - WORKING
-Have 1 button to perform a water change, this will turn off the canister filter relay and turn on the drain valve relay, then when the lower float switch activates it will turn off the drain relay and turn on the top up pump relay. Once the water level reaches the top float switch it will turn off the top up pump and turn the canister filter relay back on. - WORKING but issues above!
-pre heat header tank water using a water heater connected to a relay, prior to starting a water change. -NOT ADDED YET
-work with DS1302 RTC module to perform automatic water changes on a schedule - NOT ADDED YET
-use an ethernet shield to report water changes and temps via local network.
the issue I have is that I am trying to use statechange for the float switches to trigger events, the events trigger fine but the LCD doesn't update to the appropriate message as I believe they are all constantly trying to overwrite each other on the screen. This leads me to believe the statechange actions isnt actually working and the system is just reacting to the current state of the float sensors rather than only performing an action when the float sensor state changes.
Code is below, the hardware I am using is:
Arduino Uno 3
I2C 20x4 Blue LCD Module
2 x DS18B20
DS1302 RTC
2 x Float switch
4 x Relay
#include <Wire.h> // Comes with Arduino IDE
#include <LiquidCrystal_I2C.h> //For LCD
/*-----( Declare Constants )-----*/
/*-----( Declare objects )-----*/
// set the LCD address to 0x27 for a 20 chars 4 line display
// Set the pins on the I2C chip used for LCD connections:
// addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
//temperature probes
#include <OneWire.h>
#include <DallasTemperature.h>
//adds libraries for the temp sensors
/*-----( Declare Variables )-----*/
// temp sensor Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices
// (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
//RELAY setup
#define BUTTON 4 //water change button
#define DRAINVALVE 7 //Solenoid valve to drain main tank
#define TOPUPPUMP 8 //Pump to top up main tank from top up tank
#define CANISTER 9 //Canister Filter pump Relay
#define TOPUPHEATER 10 //HEater for Top Up Tank
const int TANKFULL = 5; //define sensor pin for top float switch
const int TANKLOW = 6; //define sensor pin for low float switch
int TANKFULLState = 0; //current state of tank full sensor
int LastTANKFULLState = 0; //previous state of tank full sensor
int TANKLOWState = 0; //current state of tank low sensor
int LastTANKLOWState = 0; //previous state of tank low sensor
void setup() /*----( SETUP: RUNS ONCE )----*/
Serial.begin(9600); // Used to type in characters
//set pins as inputs for float switches and button, no need for external resistor
pinMode(BUTTON, INPUT_PULLUP);
pinMode(TANKFULL, INPUT_PULLUP);
pinMode(TANKLOW, INPUT_PULLUP);
//set pins as output for relays
pinMode(DRAINVALVE, OUTPUT);
pinMode(TOPUPPUMP, OUTPUT);
pinMode(CANISTER, OUTPUT);
pinMode(TOPUPHEATER, OUTPUT);
//sets default relay states
digitalWrite(DRAINVALVE, HIGH);
digitalWrite(TOPUPPUMP, HIGH);
digitalWrite(CANISTER, LOW);
digitalWrite(TOPUPHEATER, HIGH);
//starts with canister on, all other relays off
lcd.begin(20, 4); // initialize the lcd for 20 chars 4 lines, turn on backlight
// ------- Quick 3 blinks of backlight -------------
for (int i = 0; i < 3; i++)
lcd.backlight();
delay(100);
lcd.noBacklight();
delay(100);
lcd.backlight(); // finish with backlight on
//-------- Write characters on the display ------------------
// NOTE: Cursor Position: Lines and Characters start at 0
lcd.setCursor(3, 0); //Start at character 4 on line 0
lcd.print("Starting...");
}/*--(end setup )---*/
void loop() /*----( LOOP: RUNS CONSTANTLY )----*/
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
sensors.requestTemperatures(); // Send the command to get temperature readings
lcd.setCursor(0, 0); //Start at character 4 on line 0
lcd.print("Tank Temp:");
lcd.print(sensors.getTempCByIndex(0)); // Why "byIndex"?
// You can have more than one DS18B20 on the same bus.
// 0 refers to the first IC on the wire
lcd.setCursor(0, 1); //Start at character 4 on line 0
lcd.print("Topup Temp:");
lcd.print(sensors.getTempCByIndex(1)); // Why "byIndex"?
if(digitalRead(BUTTON) == LOW) // water vhange button pressed
digitalWrite(CANISTER, HIGH); //turn off canister filter pump
digitalWrite(DRAINVALVE, LOW); //turn on drain valve
lcd.setCursor(0,3); // bottom line of lcd
lcd.print("Draining Water "); //display message
delay(10000);
TANKLOWState = digitalRead(TANKLOW); //read the tanklow sensor state
if(TANKLOWState != LastTANKLOWState); //has it changed since last time?
if(TANKLOWState == LOW){
digitalWrite(DRAINVALVE, HIGH); //turn off drainvalve
lcd.setCursor(0,3);
lcd.print("Starting Refill");
digitalWrite(TOPUPPUMP, LOW); //turn on top up pump
TANKFULLState = digitalRead(TANKFULL); //read the tanklow sensor state
if(TANKFULLState != LastTANKFULLState); //has it changed since last time?
if(TANKFULLState == HIGH)
digitalWrite(TOPUPPUMP, HIGH); //turn off top up pump
lcd.setCursor(0,3);
lcd.print("TANK FULL ");
digitalWrite(CANISTER, LOW); //turn on canister filter pump
else if(TANKFULLState == LOW)
{digitalWrite(CANISTER, HIGH); //turn off canister filter
lcd.setCursor(0,3);
lcd.print("TANK LOW ");
/* ( THE END ) */
