I am doing a project with sensor
function:
if sensor sense object and sensorvalue >400
press button left and right and motor on
However I got problem that although sensorvalve > 400 & right button and left button is press nothing happened.
And is Serial monitor didnt show 'ON'
int pMR_DIR = 4;
int pMR_PWM = 5;
int pRightButton = 2;
int pLeftButton = 3;
int RightbuttonStatus = 0;
int LeftbuttonStatus = 0;
int MR_Spd = 70;
int ML_Spd = 70;
int Right_IR = A2;
int SensorState = 0;
int LastSensorState = 0;
float Right_IR_Value;
pinMode(pMR_DIR,OUTPUT);
pinMode(pMR_PWM,OUTPUT);
pinMode(pRightButton,INPUT);
pinMode(pLeftButton,INPUT);
int Right_IR_Value = analogRead(Right_IR);
int RightbuttonStatus = digitalRead(pRightButton);
int LeftbuttonStatus = digitalRead(pLeftButton);
Serial.print("Right_IR=" );
Serial.println(Right_IR_Value);
if (Right_IR_Value > 400) //Sensor sense object
SensorState = 1;
if (Right_IR_Value < 400) //no object
SensorState = 0 ;
if (!SensorState == LastSensorState)
Serial.print(''ON'');
if (RightbuttonStatus == HIGH && LeftbuttonStatus == HIGH ) //2 button press
digitalWrite(pMR_DIR,LOW);
analogWrite(pMR_PWM, MR_Spd*1.3);
Should you just be assigning a value to sensorstate, instead of using it in the digitalwrite function.
digitalWrite(SensorState, HIGH); .... this appears to be wrong
Should it be SensorState=1 ?
Steve
UKHeliBob:
So what is the problem ?
This if statement is part of the problem:
Both those variables are set to zero when initialized and there is nothing in your code that changes them.
Also, use of SensorState to specify a pin in digitalWrite calls means you're manipulating pin zero, which is used by Serial.
C strings take double quotes, not single. This:
Serial.print('ON');
Should be:
Serial.print("ON");
How have you got your buttons wired, do you have pullup or pull down resistors?
What model Arduino are you using?
Thanks.. Tom..
And, is there a pin called SensorState???
Steve
TomGeorge:
Thanks.. Tom..
Using arduino uno and I used normal resistor and all the switch and motor is working perfectly before I doing this program
steve1001:
Steve
Nope,and I edit now
digitalWrite(SensorState, 1);
What do you think that command will do ?
Which pin number is SensorState ?
UKHeliBob:
I edited this line to
SensorState = 1
Please post your complete program as it is now and describe any problems you are having
Please do not update your code in old posts, please post a fresh code each time you edit.
Changing old code in old posts does not help anyone trying to use this thread to help with their code problems.
Thanks.. Tom...
