have to be placed in setup?
Place this in a function that runs regularly.
static keeps the variable from resetting.
Set trigger = 1; after the alarm time, then things will happen only once.
Use a Flag variable to enable once per hour operation.
if (now.minute() == 12 && enableFlag == true)
enableFlag = false; //disable this condition
if (now.minute() == 13) // at this time we are free to enable the flag again
enableFlag = true;
enableFlag = true;
But this is another way of writing bricoleau's state function?
Here enableFlag must be 1 first time, then it is set by the if function loop? So instead of "trigger", you use "enableFlag"?
Pretend you’re the processor and step through it manually. Repeatedly enter ‘loop()’ from the top and execute each statement in sequence – just like the processors does. Keep track of hours, minutes, and trigger on a piece of paper.
Watch what happens as you enter loop() before the time is 20:12.
Watch what happens as you enter loop() the FIRST time that time equals 20:12.
Watch what happens as you enter loop() the on subsequent times that time equals 20:12.
Watch what happens as you enter loop() when the time is greater than 20:12.
Watch what happens as you enter loop() the FIRST time that time equals 00:00.
Repeat the cycle. You might just have another aaaaaaaaaaaaaaahhhh moment.
gfvalvo:
Pretend you’re the processor and step through it manually. Repeatedly enter ‘loop()’ from the top and execute each statement in sequence -- just like the processors does. Keep track of hours, minutes, and trigger on a piece of paper.
Indeed, you just got another kudo ;D thanks!! I will remember this post forever.
Here enableFlag must be 1 first time, then it is set by the if function loop? So instead of “trigger”, you use “enableFlag”?
You can use as many flags as you need.
A flag can also be a number, ex:
if (counter < 4 && now.minute() == 12) //happens 4 (0-3) times at 12 min after the hour
counter++;
if (counter != 0 && now.minute() == 13) //at this time we are free to enable the flag again
counter = 0;
A flag allows something to happen at a ‘given time’.
You then disable the flag.
You then enable the flag as needed after the ‘given time’ has past.
You could also do something like this with the dateTime library:
(untested)
setup()
time_t eventTime = makeTime(&tm); // time of day that you want an event
loop()
if (now() >= eventTime)
eventTime += SECS_PER_DAY;
doDailyEventStuff();
Hi aarg, nice to know. But in this case I use no library for DS3231; just #define DS3231_I2C_ADDRESS 0x68
and direct register requests. The example by bricoleau had been adjusted by me for that purpose in my actual program.
I use
Wire.beginTransmission(DS3231_I2C_ADDRESS);
Wire.write(0); // set DS3231 register pointer to 00h
Wire.endTransmission();
Wire.requestFrom(DS3231_I2C_ADDRESS, 7);
Actually, if you use == you risk the chance of missing the target time if the processor is busy doing something else. If you use > or >= you solve that problem.
aarg:
Thanks!! Very useful.. But I guess this applies for seconds, not for minutes or hours?
This only works if now.hour()== 20 etc..
Or am i wrong?
It looks to me like this would trigger any time the hour is greater than 20. Seems strange. Am I wrong? Isn't the idea to restrict it to a specific hour, minute and second?
aarg:
Have a look at post#6; I did the check and it only triggers once, when it is 20:12.
brice3010:
Edit - that is because 20:10 is still less than 21:00
My question is, why is that check in there at all? It makes no sense. This code will trigger twice, once at 20:12, and once again at 21:00. Is that what you want?
