I want to turn on red/blue/green leds with specific thresholds, depending upon sensor input. With other sketches, the sensor functions but not with this. I obviously don't know the state machine procedure well enough to pull this off. Would appreciate help. Thanks.
int redLED = 13 ;
int blueLED = 12;
int greenLED = 8;
int sensor = 1;
int state = 0;
#define GREEN 0
#define BLUE 1
#define RED 2
sensor = analogRead(1);
pinMode(redLED,OUTPUT);
pinMode(blueLED,OUTPUT);
pinMode(greenLED,OUTPUT);
void loop(){
if(sensor < 1023) {
switch(state) {
case GREEN:
if((sensor >0) && (sensor < 600)) {
digitalWrite(greenLED,HIGH);
digitalWrite(blueLED,LOW);
digitalWrite(redLED,LOW);
case BLUE:
if((sensor >601) && (sensor < 800)) {
digitalWrite(greenLED,LOW);
digitalWrite(blueLED,HIGH);
case RED:
if((sensor >801) && (sensor < 1023)) {
digitalWrite(redLED,HIGH);
Serial.println(sensor);
An error occurs when I run your code: "expected unqualified id before numeric constant". This is the error I find most difficult to resolve. I have downloaded the library. What am I doing wrong? Appreciate your help.
#include <FiniteStateMachine.h>
//initialize states
State Red = State(red);
State Green = State(green);
State Blue = State(blue);
FSM ledStateMachine = FSM(On); //initialize state machine, start in state: On
int sensor = 0
void setup(){ /*nothing to setup*/ }
//poor example, but then again; it's just an example
void loop(){
if((sensor >= 0) && (sensor <= 600)) {
ledStateMachine.transitionTo(Red);
if((sensor > 601) && (sensor <= 800)) {
ledStateMachine.transitionTo(Green);
if((sensor > 801) && (sensor <= 1023)) {
ledStateMachine.transitionTo(Blue);
ledStateMachine.update();
//utility functions
void red(){ /*implement*/ }
void green(){ /*implement*/ }
void blue(){ /*implement*/ }
//end utility functions
You need some digitalWrite(xyzLED,HIGH); and digitalWrite(xyzLED,LOW); in there to make them blink.
[edit]Where xyz is either one of red blue green[/edit]
With this sketch, the light does not move from green, regardless of sensor data. Another dumb mistake, no doubt.
int greenLED = 12;
int redLED = 13;
int blueLED =8;
int sensor = 0;
unsigned long starTime;
int flashRed = 20000;
const int numReadings = 3;
int readings[numReadings]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int average = 0;
//initialize states
FSM ledStateMachine = FSM(Green); //initialize state machine, start in state: On
void loop(){
//sensor = analogRead(1);
// subtract the last reading:
total= total - readings[index];
// read from the sensor:
readings[index] = analogRead(sensor);
// add the reading to the total:
total= total + readings[index];
// advance to the next position in the array:
index = index + 1;
// if we're at the end of the array...
if (index >= numReadings)
// ...wrap around to the beginning:
index = 0;
// calculate the average:
average = total / numReadings ;
if((sensor >= 0) && (average <= 510)) {
if((sensor > 511) && (average <= 549)) {
if((sensor > 550) && (average <=1023)) {
Serial.println(average, DEC);
//utility functions
void red()
digitalWrite(redLED, HIGH);
digitalWrite(greenLED, LOW);
void green()
void blue()
digitalWrite(redLED, LOW);
What kind of values do you see printed for average?
How about adding a print after reading the sensor, so you can be sure that average is being computed correctly? Maybe add print statements in each if block to verify that the correct transitionTo statement is being invoked.
I found the error involving the sensor pin and changed both to "1" but the results are the same; no change. Sorry, not quite sure what you are pointing to regarding the sensor.
You have sensor as the pin that the data is coming in on. It will never be greater than 1, so, depending on the average value of the sensor data, the first if test may, or may not, be true, but none of the others can ever be true.
The sensor is from a mic via LM386 that has been rectified and works fine on another sketch with simple if statements (but the results are not stable so I was looking for an alternative).
