Static Text display on P10 LED Display
Good Morning Everyone.
i’m trying to display static text to p10 led module via arduino ethernet shield please help me where i am wrong
this is my code…
Includes
#include <SPI.h> //SPI.h must be included as DMD is written by SPI (the IDE complains otherwise)
#include <DMD.h> //
#include <TimerOne.h> //
#include “SystemFont5x7.h”
#include “Arial_black_16.h”
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip = { 192, 168, 1, 125 }; // ip in lan
byte gateway = { 192, 168, 1, 1 }; // internet access via router
byte subnet = { 255, 255, 255, 0 }; //subnet mask
// telnet defaults to port 23
EthernetServer server(23);
boolean alreadyConnected = false; // whether or not the client was connected previously
//Fire up the DMD library as dmd
#define DISPLAYS_ACROSS 1
#define DISPLAYS_DOWN 1
DMD dmd(DISPLAYS_ACROSS, DISPLAYS_DOWN);
Interrupt handler for Timer1 (TimerOne) driven DMD refresh scanning, this gets
called at the period set in Timer1.initialize();
void ScanDMD()
dmd.scanDisplayBySPI();
String inputString = “”;
char c;
Ethernet.begin(mac, ip, gateway, subnet);
// start listening for clients
server.begin();
Timer1.initialize( 5000 );
Timer1.attachInterrupt( ScanDMD );
dmd.clearScreen( true );
dmd.selectFont(Arial_Black_16);
if(client.available())
c = client.read();
inputString += c;
char newStrings[256];
int sLength=inputString.length();
inputString.toCharArray(newStrings,sLength+1);
dmd.drawString(0,0,newStrings,sLength,GRAPHICS_NORMAL);
dmd.clearScreen( false );
//dmd.drawMarquee(newStrings,sLength,(32DISPLAYS_ACROSS)-1,0);
////dmd.drawMarquee(“Scrolling Text testing”,22,(32
// long start=millis();
// long timer=start;
// boolean ret=false;
// while(!ret){
// if ((timer+30) < millis()) {
// ret=dmd.stepMarquee(-1,0);
// timer=millis();
// delay(2);
Where you are wrong is not reading the forum guide. No code tags, no explanation of what the sketch actually does and what you wanted it to do, no link to the spec of the panel… Please read the whole of the forum guide, then modify and fix your post above.
