I'm trying to make my first code using class (never used it before), a static variable that a declared inside the class is being shared with the objects... Is there a way to make each object have its own static variable?
Since the variable is shared (nextToggle) the LEDs don't toggle in the specified time.
class led
public:
uint8_t ledPin;
unsigned long delayMilliseconds;
Funcao para mudar o estado do led ele pode ser chamada constantemente pois
o led somente sera atualizado quando o perido indicado tiver passado.
parametros:
ledPin - pino em que o LED esta conectado
delayMilliseconds - Tempo para que a proxima atualizacao seja aceita
void toggleLed(uint16_t delayMilliseconds)
static unsigned long nextToggle = 0;
if ((digitalRead(ledPin)) && (millis() >= nextToggle))
digitalWrite(ledPin, LOW);
nextToggle = millis() + delayMilliseconds;
else if ((!digitalRead(ledPin)) && (millis() >= nextToggle))
digitalWrite(ledPin, HIGH);
Desligar o Led
void turnOffLed ()
Ligar o Led
void turnOnLed ()
Confifura o pino como saida
void setAsOutput()
pinMode(ledPin, OUTPUT);
Configura o pino como entrada
void setAsInput()
pinMode(ledPin, INPUT);
led ledStatus, ledMQTTActivity;
ledStatus.ledPin = ledStatusPin;
ledStatus.setAsOutput();
ledMQTTActivity.ledPin = ledMQTTActivityPin;
ledMQTTActivity.setAsOutput();
ledStatus.toggleLed(1000);
ledMQTTActivity.toggleLed(250);
