Hello
is there any way to create a StaticJsonDocument using a variable as a size:
Example:
String myJson = "{\"hello\":\"world\"}"; //(the size can change)
StaticJsonDocument<myJson.length()> jsonDocument;
I get the following error:
exit status 1
call to non-constexpr function 'unsigned int String::length() const'
I'm using a <ArduinoJson.h> library (6.18.4)
thanks
I just looked at the documentation:
"In older versions, DynamicJsonDocument
was able to grow if needed. Starting with version 6.7.0 , DynamicJsonDocument
has a fixed capacity, just like StaticJsonDocument
. This change allows better performance, smaller code, and no heap fragmentation ."
I think that means 'No, there is no way to set the size of a JsonDocument to a run-time calculated value.'
batwam
February 8, 2022, 3:58am
3
Not exactly optimal but I guess a work around could be to include a bunch of if statements and allocate a different "static" size depending on the length of the string.
system
Closed
August 7, 2022, 3:58am
4
